Mar 11, 2012 11:52 AM
POD 2.0 Pro with OSX Lion
Like (0)
Hi ,
somebody has problem with MIDI conections in Lion? i have a POD 2.0 Pro and lion doesnt show me the MIDI ports, i tryed in another computer with Snow Leopard and i can select the MIDI ports and do the Conction with the interface.
if somebody can help me with taht i will be really happy
Cheers
hello
you do not mention what Midi interface you're trying to use
please note, Line6 advises the use of M-Audio's Midi UNO, as other devices may not meet the needed specs, see http://line6.com/support/docs/DOC-4725
line6antonio
i am using Digidesign MBox 2 USB audio MIDI interface
chhers
you're not mentioning in which Line6 software your Midi interface is not appearing
did you use the same Mbox on the other Mac?
please setup the connection using Line6 Monkey (select 'Use Midi Cables' on startup), and tell me the result
if needed, please upload screenshots
hi ,
ok i am using a MBOX 2 USB Audio MIDI interface, and a POD 2.0 Pro,
the software for the POD that i am using is the Line 6 Edit.
so when i try to select the MIDI port, the program doesnt show me anything,
but when i conecte the MBox 2 to another mac with snow Leopard, the program allowed me do the MIDI port selection.
so i guess this is a LION problem or something else,
thank and cheer
Javier
are you sure the Mbox drivers are installed?
can you see your Mbox as a Midi interface in the Mac's system?
do other software in it detect the Mbox as a Midi interface?
yes, i instaled the drivers again in my mac, and also i installed the same drivers in the other mac with snow leopard. the other softwares recognize the Mbox
are the drivers updated?
have you tried different USB ports?
Hi antonio,
well i re installed the drivers, but still the same problem, so i just got a MIDI interface , LogiLink and everything works fine now, i dont know what was the problem but now its seems like i can edit the programs, thanks for the help anyway. cheers
