Mar 14, 2012 1:35 PM
Gearbox doesn't receive the signal
Like (0)
I've recently found my old guitarport and I tryed to install it on my windows xp.
I've downloaded all the uploads required by Line 6 Monkey (drivers, USB..) but when I open Gearbox it usually doesn't receive the guitar signal and when it does it stops working after some seconds. What should I do? (Thanks you, and excuse my english!)
What stops working after some seconds?
Does the GearBox program crash?
Does your computer crash/freeze?
Are you receiving a guitar input signal but not hearing the output? If so make sure to connect your speakers or headphones directly to the outputs on the Guitarport in order to hear playback.
Ok, i've just found the problem: it was a defective USB cable. I thought it wasn't possible because the led turned into green, but now it works. Thank you anyway!
Hey.
I have the same problem. How did you get it to work?
