296 Views 2 Replies Latest reply: Aug 8, 2012 1:52 AM by xaled RSS
TYancy Just Startin' 1 posts since
Mar 17, 2012
Mar 17, 2012 9:21 PM
Firmware update killed audio
I conected the unti and it performed correctly, the I was presented with a notice about the firmware update. I performed the firmware update without any problems whatsoever. Then the unit went dead. No input and no output. I've been handling firmware updates in an IT capacity for many years. Nothing was disconnected during the update and no other signs were present to indicate a problem.
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Mar 19, 2012 10:58 AM (in response to TYancy)
    Re: Firmware update killed audio
    Did you try disconnecting and reconnecting the Mobile In to your iOS device after the update finished?
    Does the light on the your Mobile In blink when you connect it?
    Do you have access to another iOS device so you can see if another iOS device can recognize the unit?
    Check your iPhone or iPad to be sure the latest version of the iOS operating system is installed update if necessary, instructions to do so can be found here. Check Settings > General > Accessibility, and then turn Mono Audio off. If the adaptor is still not being recognized by your Apple® device, it may be necessary to backup and restore your current iOS installation using Apple®’s instructions located here.
    • xaled Just Startin' 2 posts since
      Aug 8, 2012
      Aug 8, 2012 1:52 AM (in response to Line6Don)
      Same story here,
      Iphone 4, 5.0.1, did the firmware update, everything went good.
      Firmware update happened before mobile pod update
      Result:
      • Mobile in is not recognized by mobile pod.
      • Garage band shows the plug sign, but no sound can be heard. Monitoring shows incoming signal. Recording with GB works, but sound is crappy.
      Once connected mobile in blinks short, much shorter then before update.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
