Mar 30, 2012 2:04 AM
How to save hardware input selection in POD farm2.5
Like (0)
Hi
I'm using Pod farm with RME babyface. (Hi-z input : analog input 2)
When I use POD farm standalone, I have to select hardware input2 in RME babyface in POD farm's hardware preference tab.
shutdown and restart POD farm, last assinged setting had gone away , then I have to reassign Hardware input everytime to sound properly!
Do you have any idea to save hardware setting in POD farm2.5 ?
I have exactly the same problem. RME HDSPE, analog input 2, Windows 7. Have you found any solutions?
Thank you.
When using POD Farm 2.5 stand alone with a third party audio interface. The hardware input settings will not be saved.
If you want to use the same input from your interface, I would suggest that you use your DAW to create a session in which it simply has one audio track with POD Farm inserted onto it. You than can configure the input in which you would like to use within the DAW itself. Save the session when you are done. Instead of using POD Farm stand alone, use this session in your DAW instead. Now if inspiration hits, you can record it too!
