653 Views 13 Replies Latest reply: Apr 2, 2012 10:39 AM by Celestial93 RSS
Celestial93 Just Startin' 10 posts since
Nov 14, 2009
Apr 1, 2012 11:40 AM
POD HD PRO/STUDIO MONITOR PROBLEM
This wasn't happening before, but today when I started up my POD HD Pro, the sound was coming out at the proper volume through one monitor and extremely quiet coming out of the other. The monitors are brand new, as is the POD, so I doubt there's
any serious problems; however, I have checked the connections and everything is in place. I was hoping the problem has something to do with the configuration, and I could fix this with a couple of clicks.
Anybody have any ideas?
Thanks
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Apr 1, 2012 11:50 AM (in response to Celestial93)
    Re: POD HD PRO/STUDIO MONITOR PROBLEM
    Have you checked the Mixer settings in the HD Pro? Path volume and panning could be the culprit.
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Apr 1, 2012 12:19 PM (in response to Celestial93)
    There are a few users of the HD Pro reporting some volume dropout issues with the latest firmware installed. See this post for examples ==> http://line6.com/support/message/353898#353898
    One fix is to drop the firmware back down to version 1.31.  This loses you a bit of functionality but is probably less frustrating thatn the alternative.  The issue has been known about for a while so there may be a fix in the offing with version 2.0 ... due out this week.  Or not !
        Apr 1, 2009
        Apr 2, 2012 9:58 AM (in response to Celestial93)
        What do you hear through the HD Pro headphones jack?
        EDIT: Another test: physically switch your monitor jacks between L/R channels.
            Apr 1, 2009
            Apr 2, 2012 10:28 AM (in response to Celestial93)
            Since it sounds proper through the headphones jack, I think that means that the problem is either the L or R physical output jack on the Pod (whichever jack leads to the quiet monitor) or the monitor itself.
            Your description of what happens when you switch jacks is ambiguous: is it the same physical speaker that is quiet when you switch jacks, or is it whichever speaker is connected to a  specific HD output? If the former, it's your monitor that is the problem. If the latter, it is probably your HD device.
            The other thing to test is the cables themselves, connecting your HD to the monitors. One of them could be faulty, while your HD and monitors are all fine.
  • L6JMan Just Startin' 4 posts since
    Dec 27, 2007
    Apr 1, 2012 1:57 PM (in response to Celestial93)
    I may have the same situation - are you using the XLR connection?  If so, I think I've narrowed it down to being a problem with my monitor and NOT the HD500.  Perhaps that's not the case though.  It is an off & on problem that I can't seem to figure out completely.  I'm using Mackie MR5's.
      • lforward00 Just Startin' 34 posts since
        Jun 18, 2007
        Apr 2, 2012 10:03 AM (in response to Celestial93)
        It certainly is possible that you have a defective monitor. I had that problem when I first bought my monitors a couple of years ago, one was dead and had to be returned immediately and exchanged for working one.
