Apr 4, 2012 1:31 PM
Latency with Windows 7 and Guitar Port
Like (0)
Hi, I am having difficulty with latency using my Guitar Port. I just went to a new computer (high end machine) but am running Windows 7. I have tried all of the possible settings and get no relief. Is there a significant difference in using Windows 7 vs. Windows XP with the Guitar Port hardware? I never had the problem with XP. Will going to newer hardware eliminate this problem? Thanks!
I don't know if you still have this issue, but maybe what worked for me will work for you. I had it all working perfectly on my Windows 7, Core I7 machine. Then I started fiddling around with audio settings to see if I could bypass Guitarport and go straight into Gearbox using a Rocksmith Real Tone cable. I couldn't. Then I plugged Guitarport back in, I had horrible latency that wasn't there before, like a half-second delay. I spent two hours trying everything I could think of--adjusting system audio setting, soundcard settings, Gearbox settings, restarting everything. Nothing worked. Finally I launched Line 6 Monkey and saw that there was a firmware update available for the Guitarport. I installed it...latency gone.
