Apr 7, 2012 9:41 PM
Spider IV 30 amp models and other control settings
Like (0)
I am having a hard time getting consistent sound from my IV 30. Some days it sounds perfect, some days not so much.
My interpretation of the manual is that if I switch to a different amp model (e.g. switch from Blues Red to Metal Green) the new model will set all of the other settings automatically - Drive, Bass, Mid, etc.) If I then manually change one or more of the other settings, it will override the default - until I either turn the power off, or choose a different amp model.
Is that correct? Or do the other settings always impact the tone?
Thanks.
Sounds like you have it correct - when you select a preset the sound changes to that with all the default settings for that preset. Then when you move a knob you have changed the sound - unless you save the changed sound, the next time you select that preset, you will be back to the original sound.
thanks
