176 Views 1 Reply Latest reply: Apr 12, 2012 6:53 AM by mazuwa RSS
akalkman Just Startin' 3 posts since
Nov 9, 2011
Apr 12, 2012 6:29 AM
POD HD Pro sample rate?
Does anyone know what the POD HD Pro's sample rate is? I'm trying to run my POD into my interface via the S/PDIF out of the POD, to a converter, and then into the optical in on my interface. My interface is requesting the sample rate of the hardware. Also, does anyone else use their POD in this manner? I could use some pointers. Thanks
  • mazuwa Iknowathingortwo 371 posts since
    Jul 7, 2006
    Apr 12, 2012 6:53 AM (in response to akalkman)
    Re: POD HD Pro sample rate?
    The sample rate is adjustable inside the pod from 44.1kHz up to 96 kHz.
    To do this hold the view button to go inside the system configuration and go to the S/PDIF page.
    All you have to do is to find a common value with your other device. The higher the value the higher the possible transmitted frequencies and quality, but also the more memory and cpu required while recording.
    Bit depth is at 24 bit.
    Set your pod as master for best clock synchonization results.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
