465 Views 14 Replies Latest reply: Aug 20, 2012 3:36 PM by mdmayfield RSS
mdmayfield Just Startin' 353 posts since
Feb 24, 2007
Apr 14, 2012 1:32 PM
Intermittent problem with VDI communication
I have a Pod HD500 and a Variax 300. Most of the time, everything works as expected with patch changes.
Sometimes, intermittently, something will happen that causes these symptoms:
1. The HD500 will not boot with the VDI connected; it gets stuck in a reset loop.
2. If I disconnect the VDI cable, the HD500 will then boot.
3. If I then reconnect the VDI, the HD500 does NOT recognize that there is a Variax connected (no Variax shown in the Setup screen).
4. However, the Variax *audio* DOES work.
Occasionally, I'll start a playing session where everything works as normal, and suddenly the Variax stops responding to HD500 patch changes. At that point, this happens:
5. There is apparently no MIDI program change or Tone CC communication, in either direction, between the Variax and HD500 (Variax patches don't change when HD500 patches change, and moving the Tone, 5-way, or Model Select controls with the Variax screen up on the HD500 does not show updates).
If at that point I then power off the HD500 and turn it back on, I experience symptoms 1-4 as above.
I've tried two different VDI cables, and visually inspected both of the Neutrik Ethercon jacks (in the HD500 and Variax). Neither seems to have any bent pins or debis in them.
What further steps can I take to troubleshoot this? I need to have 100% reliability at gigs in order to make use of the Variax.
Thanks,
Matt
    • amx05462 Power User 3,495 posts since
      Sep 1, 2008
      Apr 14, 2012 3:51 PM (in response to mdmayfield)
      Re: Intermittent problem with VDI communication
      id check your vdi connectors  on both the guitar and  the  hd  for a slightly lowered  wire connector. they have to be all the same  height. a slightly lowered  one   will dcrease  the spring tension of the connection. if you find one  slightly lowered   you can fix it by  taking a bread tie  stripping the   plastic off it  bend the end  into a J shape  and carefully   working it  under the connector and pulling it up. this is tedious work though.  most likely the problem. the other  problem could be   the cable itself if the  actual plug  has  slipped  back into the metal bezel just a bit.   the metal bezel  limits the depth of the plug. so if it  has moved a bit you have a loose  connection
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
