80 Views 0 Replies Latest reply: Apr 14, 2012 3:16 PM by howarddavidp RSS
howarddavidp Just Startin' 18 posts since
Apr 12, 2012
Spider 4 x 12 cabinet wiring?
Hello,
I 1st weant to explain my knowledge of 1/4 in jacks, the difference between STEREO and MONO, what a TRS cable is, etc...  I have a VDRUM set, so I learned the different with respect to the plugs, whereas a MONO has 1 ring and the tip, and a TRS has 2 rings and the tip.  SO, that helped me understand my Spider 2 amp outputs, I think.
Here is my understanding:
My Head (the 150watt SP2) has 2 physical output female jacks, wired in STEREO, requiring 8 outs to be input in each channel.
SO, if I used a splitted, would it be safe to say I would need to have 4 x 8 Ohm MONO speakers?
Is that how my cabinet is wired?  Not in series, or parallel, just 4 x 8 Ohm speakers wired up in STEREO to 2 jacks?
So, if I used a STEREO to MONO splitter, I could use a Marshall 8 Ohm mono cabinet?  I saw a cabinet that had 4 x 8 Ohm wired in series+parallel, would this work to add another cabinet?
THanks,
David
