218 Views 6 Replies Latest reply: Apr 27, 2012 7:50 PM by spikey RSS
paligulus Just Startin' 32 posts since
Oct 26, 2006
Apr 26, 2012 7:16 AM
Tubes go Mid gig - options?
Hi Folks,
    I have ordered a DT25 and this will be my first tube amp.
     I will be using the DT25 with the POD HD300.  I am currently just using the HD300 Line out straight to desk.  I plan to use the Line out from the DT25 as the reviews have been very good.
     I am assuming this will sound somewhat "better" as the DT25 use the tubes to some extent for Line out right?
     Anyway, if the tubes blow in the amp mid gig - what is the best option?  It seems like it should be quick to bypass tubes in a gig situation so I am just wondering what users would do,
      Thanks,
  • bartpuglise Just Startin' 104 posts since
    Mar 16, 2006
    Apr 26, 2012 10:13 AM (in response to paligulus)
    Re: Tubes go Mid gig - options?
    I have a DT50 and a HD 500. I have 2. Setlists with the same patches but one is set up with pre-amp settings(for DT 50) and one set up with full amp models(for direct to PA) If the tubes take a sh*t switch over to other setlist go direct out of HD*** and keep playing!!!!
    • hollis1003 Iknowathingortwo 342 posts since
      Feb 6, 2007
      Apr 26, 2012 12:13 PM (in response to bartpuglise)
      I have the same thing.  I also use the full amp models to practice at home, plugging an mp3 player into the POD.
      Also, if the POD HD takes a dump I can play straight through the DT-50 if needed.
      With the DT-25 you can go into Low volume mode (LVM) and then you DO NOT have to have the speaker connected to get the direct output to work.  However, you will not be hearing real tubes.  If you are using the tubes it MUST BE plugged into a speaker or a "load box".  If you do not, you will damage the amp.
    Dec 22, 2006
    Apr 27, 2012 6:11 AM (in response to paligulus)
    you can also, have the amp serviced and order matched set tubes, so that you have spares that can be swapped without being re-biased/serviced....
    i don't think that this would be a common scenario... so you might be over-thinking it a bit.
  • spikey Just Startin' 378 posts since
    Feb 1, 2007
    Apr 27, 2012 7:50 PM (in response to paligulus)
    I would say if this happened to me I would think about changing equipment manufacturers asap... I would hope that Zap is correct in that this prob. isnt very common.
