1366 Views 12 Replies Latest reply: Apr 12, 2013 12:03 PM by samlimster RSS
samlimster Just Startin' 10 posts since
Mar 27, 2012
Apr 30, 2012 5:16 PM
Mounting your HD500 into a Rondo Music Case.
Hey all.
From the great reviews from this forum, I bought one of these $35 cases for my HD500 from here: http://www.rondomusic.com/pdc410d.html
The HD500 fits perfectly in it and there's just enough clearance at the back so that cables can be plugged in without having to remove the unit from the case.  The only problem was how to properly secure the HD500 to the case so that it doesn't bounce around in travel.  Of course, you could pack more foam into it to hold things in place, but I thought it'd be great to have a bit of extra storage space on top of the HD500 for a cable or 2.
The velcro that comes with the case is pretty much useless because the HD500 has rubber feet which prevent the velcro from having contact with the fuzzy part of the case so I ended unscrewing the rubber feet from the HD500 and replacing the screws with longer ones.  This allowed me to mount the feet on the outside of the case, pass the screws right through the case wall and fasten the HD500 to it.  The rubber feet on the outside help prevent the case+HD500 from sliding around.
Here are some pics
I used 1" screws for the back and 3/4" screws for the front to angle the HD500 forward a little.  This gives even more clearance for cables plugged into the back.  Note I also used 4 rubber washers in the back and only 2 up front.  The washers I found were 1/2 the thickness of the HD500's rubber feet.  I only replaced the screws/feet on the corners of the unit.  If you want, you can replace the 2 middle screws as well.  I just didn't want more black rubber feet sticking out the side of my case
Here's what the feet look like.  I took the bottom plate off the HD500 and used it as a drilling template for where to put the holes.
The HD500 It's perfectly in this case with about 1/4" clearance on the sides and about 2" in the back
Here you can see a fairly long 1/4" cable plugged into the back and it just clears the lip of the case.
I used 4 screws, 12 rubber washers and 4 metal washers for this little project.
I'm really happy with the case.  It's amazing value for $35.  It's about as tough as your average instrument case but not as tough as a true flight case.  The walls appear to be 1/4" particle board covered with thin aluminum layer.  Now I don't have to shove my HD500 into a backpack anymore!
Enjoy!
  • samuelito2011 Just Startin' 105 posts since
    Nov 14, 2011
    Apr 30, 2012 5:30 PM (in response to samlimster)
    Re: Mounting your HD500 into a Rondo Music Case.
    That's a nice idea Bro!
    I also bought a rondo music case for my pod hd500
    this one http://www.rondomusic.com/pdc410gmsbk.html
    and it fit really nice and I still has some extra space for futures pedal... I also bought the line6 volume pedal for the PEDAL 2 and it works nicely too... THe idea you gave is a really good but what idea was remong the feet and i use velcro (no the one they provide) and i attached it like that....
    At the beginning i was dispapoing it about cause it was moving but when i bought extra and new one it kind of stick hard and now my pedal is great man...
    Your idea is really good but for me it will not work
    Just want to share it
    and thanks for the INFO!
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    Apr 30, 2012 7:03 PM (in response to samlimster)
    Great idea!  Thanks for sharing.
  • varmint Just Startin' 43 posts since
    Jan 24, 2007
    May 4, 2012 1:09 PM (in response to samlimster)
    Good work, those Rondo cases are quite a bargain.
    I did one of those for my XT Live a few years ago, but I put ALL the feet on the outside!
    http://line6.com/support/message/330017#330017
  • BigBob369 Just Startin' 58 posts since
    Nov 9, 2007
    May 6, 2012 3:07 PM (in response to samlimster)
    That's brilliant! Great idea. Nice job.
    I bought a Rondo case years ago and as long as you're not too rough on it, it should last a long time.
  • takitiger Just Startin' 5 posts since
    Nov 23, 2011
    May 18, 2012 2:07 AM (in response to samlimster)
    Hey guys,
    I am desperately looking for a case like this for my hd500
    Problem is I live in Greece, Europe and fror a 35.95$ case the shipping will be 123.67$
    Does anybody know anything how could I get something like this here?
    I'm searching and searching but......................
    Thanx guys, great work samlimster
  • retselj Just Startin' 2 posts since
    Apr 10, 2011
    Aug 24, 2012 6:33 PM (in response to samlimster)
    Salimaster,
    Thanks for the tip on the case I am very pleased with the price and quality but I have a question on the mounting. The original screws are size 4 on the hd 500 rubber feet and has
    coarse thread not sure of the pitch. I went to find some longer replacements but only found 4/40 screws but the thread was to fine the line 6 has coarse thread. How did you get the 6/32 to screw in?  Did you tap it out to the larger size?
  • pigwing76 Just Startin' 13 posts since
    May 4, 2007
    Nov 5, 2012 8:56 AM (in response to samlimster)
    Thanks for the great post!  The step-by-step detail is great, along with the side diagram.  I just got one of these cases (the black version) and should be picking up my new HD500 tomorrow. I'm hoping to be able to drill the case holes without removing the back of the unit for a template. I don't want to run into any warranty void issues should the need arise.
    Thanks!
    Jeremy
  • millemj Just Startin' 3 posts since
    Jan 17, 2012
    Apr 12, 2013 12:34 PM (in response to samlimster)
    @samlimster, thanks so much for your detailed post, it made my project go a lot faster. I use several outboard pedals and an expression pedal with my POD HD500, so I went with the extra long case shown here: http://www.rondomusic.com/pdc410h.html (note I changed this link, the one I had previously listed was wrong...)
    Took a printout of your picture to the hardware store to buy screws & washers, which all fit perfectly and according to your specifications. I ended up using 5 of the mounting holes under the POD, I just couldn't get to the center-front one. There were also a couple of screws (with feet) holding what looks like a corrugated metallic barrier inside the POD, possibly to give support to the PC board. I remove the feet from those two screws, which I replaced with flat & lock washers. I ended up with three extra rubber feet. Since this case is so wide, I was worried about the short-legged chair syndrome, so I placed those extra 3 rubber feet on the far corners of the case, for stability.
    Cheers!
Bookmarked By (2)
