549 Views 4 Replies Latest reply: Jun 14, 2012 8:02 AM by paligulus RSS
Netfly Just Startin' 40 posts since
Jan 13, 2012
May 3, 2012 1:02 PM
DT25 Cabinet simulated direct output???
Hello,
I'm really new regarding record technics and I would like to use the Cabinet simulated direct output of the DT25 to record my covers.
How the "Cabinet simulated direct output" works? Is it possible to plug the amp directly to my MacBook Pro using one of the USB port? Or I need to plug the amp into an external sound card then plug this one to my computer?
Well, I really don't understand what I need to do...??? Any help will be really apreciated!
Thx
  • fretboard-master Just Startin' 4 posts since
    Jun 30, 2009
    May 4, 2012 1:40 AM (in response to Netfly)
    Re: DT25 Cabinet simulated direct output???
    The Cab Sim direct out uses a xlr connector but perhaps its possible to use a xlr to usb cable ( sometimes called microphone to computer cable ) some have inbuilt sound cards with no need for drivers on your pc just plug and play, they are really cheap online, so unless you have an external soundcard or a spare line 6 pod that can record via usb and accept a xlr input its probably worth trying one of these cables. I want to do the same thing as you soon but havent tried it yet, I was just going to connect DT25 direct out to pod x3 mic input with a blank patch on the pod and record through that with usb to pc, but I might get one of these cables and try it myself.
      • greghall Just Startin' 160 posts since
        Feb 2, 2007
        Jun 14, 2012 1:13 AM (in response to Netfly)
        I have the same setup: HD500, DT25, Mac Book Pro, Reaper
        For recording I think you would have better success going direct from the HD500 into the Mac, and monitoring through a good set of headphones. It gives you more flexibility with the power amp, cabinet, mike modelling etc and there is less digital / analog conversion in the chain.
        If you have the DT25 in low power mode for recording, you would be using the digital power amp model in the DT25 anyway.
        The direct out is an analog signal, so to connect to a digital USB there would need to be an A/D converter in line for it to work, and the quality of these varies. I would try to avoid to much A/D and D/A conversion as it can result in tone loss.
        With the HD500 going direct to the Mac you have just one A/D conversion - the signal from your guitar into the HD500 (or none if you are using a Variax :-))
        Regards
  • paligulus Just Startin' 32 posts since
    Oct 26, 2006
    Jun 14, 2012 8:02 AM (in response to Netfly)
    I can't speak to the soundcard on the Macbook Pro, but I believe you will have more luck recording via USB from POD HD.  The HD effectively acts as a soundcard when it is connected via USB, this way you will not have latency when recording (guitar playback slower than track playback due to soundcard delay in processing signal).
    If you are to use the Cabinat out I believe you will need a recording device like Line 6's TonePort - which are really good value (I don't have experience with other recording devices).
    Best of luck
    Cheers
