287 Views 5 Replies Latest reply: May 31, 2012 4:45 PM by Line6Tony RSS
guitar4u Just Startin' 142 posts since
Jan 26, 2007
May 6, 2012 11:21 AM
DT25 PRESENCE knob doesn't sync with POD HD500
Hi guys, have any of you experienced this glitch? If not, do you have any ideas about what the problem could be? Could it be a calibration issue?
I have connected a POD HD500 (Firmware 2.02) to a DT25 head via L6 Link with a "Planet Waves PW-AES-20 AES/EBU Cable". I am running POD HD500 EDIT (version 2.0) software with a JTV 69 connected via VDI cable to the "VARIAX" input. Here is the problem:
The presence or "PRES" knob on the HD500 is NOT syncing up with the "PRESENCE" knob on the DT25 head. Whenever I make an adjustment to the PRESENCE knob on the DT25 the POD500 PRES knob will jump back and forth or not respond at all. Whatever changes I make to the PRESENCE knob on the DT25, the POD HD500 will snap back to its original, starting position.
Note: All of the other DT25 controls (Bass, Middle, Treble, etc.) appear to be syncing correctly EXCEPT that, sometimes, turning these knobs will trigger the PRESENCE knob to jump up and down a few notches (as if they are connected).
This problem is isolated to the PRESENCE knob on the DT25 Head ONLY. The HD500, by itself, does not have a problem syncing with the HD500 EDIT software.
Thank you for any help you can provide
Rich
    • Atminstone Just Startin' 10 posts since
      Jan 2, 2010
      May 15, 2012 4:11 AM (in response to guitar4u)
      Re: DT25 PRESENCE knob doesn't sync with POD HD500
      I had a similar issue with HD400 drive knob. The drive knob value changed on the POD when not touching, so it interpreted it as a change in value -> jumped back to the POD setting even when I was tweaking the DT25. I had some dirt under the knob and after some cleaning has worked fine.
      I'm not sure this is the same problem as yours. Is the presence always jumping back to 11% or is it jumping back to what the POD physical knob is showing? If it's jumping back to the POD physical position, I believe it has something to do with the actual knob.
          Jan 2, 2010
          May 15, 2012 2:09 PM (in response to guitar4u)
          I had a grain of sand or something stuck between the knob and the POD. I didn't take the knob out. I used a kitchen knife (or something that fits underneath the knob), sprayed compressed air and moved the knob from min to max a few times, while wiggling the knob, until the dirt came out.
          It was pretty clear in my case that the drive always jumped back to the pod physical position since all my patches had the same amount of drive, regardless of earlier programming.
          I wouldn't suggest removing the knob completely (since I'm not sure how to get it back on , or if it comes out in one piece). I would try cleaning under the knob manually, even though there's not much you can clean. If you have some electronic cleaner, spray some of that (just make sure the cleaner is made for electronics). Then turn the knob from min to max about 10-20 times to see if you can that way get the dirt to come off.
          It's also possible that your issue is something completely different, but then I'm afraid I can't help. But as I said, if it's jumping back to the actual POD knob position (not the same 11% regardless of what position the knob is at), then it's propably the knob.
        • Line6Tony Line 6 Support 1,917 posts since
          Jan 16, 2007
          May 31, 2012 4:45 PM (in response to guitar4u)
          It looks like your question was answered. If not, post again, as the forums are a good place to find advice about tone, computer configuration, and subjective questions about sound and application. If you have technical questions, you can create a support ticket at http://line6.com/support/...Contact Technical Support, and we will respond to you directly in the ticket.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
