1161 Views 5 Replies Latest reply: May 9, 2012 12:51 PM by daferalo RSS
Atminstone Just Startin' 10 posts since
Jan 2, 2010
May 8, 2012 12:05 PM
dt25 112 combo bias adjustment
I have a DT25 112 combo. I measured the bias voltage V2 and V3 and got the values 32.8 and 35.4 mV, with the stock tubes. From what I understand, this is pretty high compared to the specifications (25 +/- 3mV)
The next step would be to adjust the bias voltage with the trim pot, but the only problem is that it's next to the speaker, and I can't see it.
Has anyone adjusted the bias voltage on their DT25 combo? Is it somehow possible without removing the speaker? If not, is it possible to remove the speaker without disassembling the whole amp?
If I leave the bias voltage at the current values, what does it do to my amp? Is it only wearing out the tubes faster, or is it going to hurt my amp? Are there any differences in tone for better or worse?
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    May 9, 2012 1:41 AM (in response to Atminstone)
    Re: dt25 112 combo bias adjustment
    make sure you're in NFL1, pentode and class AB.  make sure the amp is fully powered on with the master volume control at min and with no guitar plugged into the input.
    If the bias still reads so high then it needs adjusting.  you may want to have an amp tech or line 6 service centre do this as you may need to remove the chassis slightly to get to the bias pot, or use a special tool that only LIne 6 service centres have.  usually it's just a screwdriver though, so it's strange that you can't get to it.
    could you send a photo of where it is?
    could you make a small L shaped tool to get access to it?
    Cheers
    Rowbi
      • daferalo Iknowathingortwo 270 posts since
        Apr 12, 2010
        May 9, 2012 7:52 AM (in response to Atminstone)
        Hi Atminstone,
        Maybe, you can find this thread interesting http://line6.com/support/message/333390#333390. Answer #8 from Andrewtorres. It seems that you might need to remove the amp out of the chasis to do so. However, I have never done this with my DT 25, so I cannot talk about the experience.
        Best Regards,
        Daf
    Apr 12, 2010
    May 9, 2012 12:51 PM (in response to Atminstone)
    To my knowledge, I think that in this article the effects of bias voltage are fairly explained: http://www.aikenamps.com/WhatIsBiasing.htm
    Best Regards,
    Daf
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
