328 Views 6 Replies Latest reply: May 13, 2012 7:54 PM by litesnsirens RSS
LarryLion Just Startin' 117 posts since
May 7, 2011
May 13, 2012 12:18 PM
Switching Outputs - POD HD500
I'd like to send acoustic setups to a PA and electrics to a standalone guitar amp, under foot control. Is there a way to do this?  I caanot seem to figure it out, I'm getting both signals to both destinations!. many thanks
Larry
  • litesnsirens Iknowathingortwo 649 posts since
    Mar 20, 2010
    May 13, 2012 2:42 PM (in response to LarryLion)
    Re: Switching Outputs - POD HD500
    Do you mean at the same time?  Here is a patch that was made by the late great Nick Mattocks.  Just change the extension back to .h5e and load it in via edit.
    This is set up to use the mags for electric and acoustic model.  The exp pedal takes you back and forth between the two sounds.  It may not be exactly what you are after
    but it should hold some clues so that you can tweak it to your liking.
    Generally, if you don't need them at the same time it's just a matter of setting up your electric presets and panning them all hard left in the mixer and any acoustic presets panned hard right (on both sides of the mixer). Then coming out of the left output of HD500 to your guitar amp and out of the right output to the PA.
  • daferalo Iknowathingortwo 270 posts since
    Apr 12, 2010
    May 13, 2012 3:05 PM (in response to LarryLion)
    Hi Larry,
    You need to have totally separated parallel paths in the preset, one for the acoustic and the other for the electric signal. To do so, at the end of your acoustic path you can place a FX loop effect block and send your acoustic sound to the PA through the FX loop send jack of your POD HD 500. It works really nice, I do it almost all the time.
    Best Regards,
    Daf
      Mar 20, 2010
      May 13, 2012 6:26 PM (in response to daferalo)
      Ya it sounds like he doesn't need both at the same time he is just looking to have electric patches going one way and acoustic patches another.  I tend to use the FX Loop as a clean boost so daferalo's suggestion of the FX loop won't work for me but if you aren't using the FX Loop for anything else I think it will work perfectly for you for this application.  With the exception that you won't be able to use the XLR's to the PA.  But you will be able to run stereo to your guitar amp and if you get the right cable you can also run stereo to the PA out of the FX Loop.  Great suggestion from Daf.
          Mar 20, 2010
          May 13, 2012 7:54 PM (in response to LarryLion)
          At this point there is no assigning the XLR's independently to the 1/4" outputs.   Although it has been a much asked for feature since the HD500 was released and apparently it was a feature on previous PODs.  So there may come a day.  Here's to hoping.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
