450 Views 4 Replies Latest reply: May 17, 2012 6:03 PM by Line6Don RSS
Hirokotzu Just Startin' 42 posts since
May 3, 2009
May 16, 2012 8:59 PM
Pro Tools 10 & UX1 signal too hot
Hey guys, I recently bought Pro Tools 10 and planned to use my Toneport UX1 with it, but am having some problems. I previously have used the toneport with Ableton Live 7 using ASIO4All to get the buffer down to reduce the latency, since the built in Line 6 driver didn't fair so well in my experience.
Anyway, right now I cannot seem to get the instrument signal to become less hot. When I play anything with normal pick attack, the signal hits 0db and is maxed out. In Ableton this was never a problem, the signal would be normal or on the weaker side if I wanted it to be, then I could always compress it if I wanted something more. Now I have the exact opposite problem. The UX1 has no pad to the instrument signal as far as I know, so could anyone give me some help on how to make the signal lower in Pro Tools 10? If I can't figure it out I might just buy a MOTU Microbook II, which the sound engineer at the studio I intern at recommended for Windows & Mac Pro Tool use. The computer that I am addressing right now is my Windows 7 desktop, which is what I do my recording on. My Macbook Pro would just be used for mixing, so ignore that.
Hope someone can help, thanks!
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    May 17, 2012 5:30 AM (in response to Hirokotzu)
    Re: Pro Tools 10 & UX1 signal too hot
    Is it the dry or wet signal that is too hot?
    If it is the wet, just turn down the channel volume on your amp model.
  • hulbert Iknowathingortwo 375 posts since
    May 12, 2011
    May 17, 2012 5:33 AM (in response to Hirokotzu)
    If you have pod farm, open up the standalone version and go to mixer view, and then pull down either the instrument fader a bit, or the 'send' fader.
    I hope that helps with the problem,
    God Bless,
    David
    Dec 22, 2006
    May 17, 2012 5:43 AM (in response to Hirokotzu)
    btw... ASIO4ALL might report less latency... but it's not true...
    first of all you are bypassing the accurate ASIO specification since ASIO4ALL is reverse engineered...
    and secondly you'd actually be bypassing the tonedirect functionality on the Line6 Driver.
    that tonedirect functionality creates a discrete path for your tone, which decreases latency beyond what your software might report.
    meaning of course that the software would report the latency incorrectly giving the appearance of more latency.
    i would check the control panel for the "hot" problem...
    there will be a gain control in the line6 applet and a +18 button... both of which might help.
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    May 17, 2012 6:03 PM (in response to Hirokotzu)
    I would suggest trying it with our latest available Windows drivers, they are available for download directly from the link below:
    Windows Drivers 4.2.5.4:
    http://line6.com/software/readeula.html?rid=4791
    We do not support ASIO4ALL drivers or how are hardware works when they are used.
    If you have any questions moving forward, please know that Line 6 is no longer supplying support via the forums. Instead, you can create a support ticket at:
    http://line6.com/support/tickets/add.html
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
