123 Views 2 Replies Latest reply: May 20, 2012 5:54 PM by davidb7170 RSS
daniel_radtke Just Startin' 1 posts since
Dec 29, 2011
May 20, 2012 1:12 PM
Alternate Tuning settings gone!
Hi all!
I hope someone can help me.
I recently bought a JTV 59 and as I was playing about, changed the DADGAD setting. I read in the manual how to reset these settings to the manufacturers settings and tryed following it step by step, but still no succsess.
All tunings are just the standard tunings and I don't know what else to do!
Many thanks!
Dan
  • davidb7170 Just Startin' 253 posts since
    May 3, 2008
    May 20, 2012 3:14 PM (in response to daniel_radtke)
    Re: Alternate Tuning settings gone!
    It sounds like you might not be in the modelling mode, but just the mag pickup mode... The alt tunings only work on the guitar models, not the mags. If this is not the case, you should contact Line6 and set up a help ticket -- they'll help you resolve it....
    Dave
      May 3, 2008
      May 20, 2012 5:54 PM (in response to davidb7170)
      A second thought -- If the procedure actually did not work on the alt tunings for the models, one way to get back the default settings would be to re-flash the guitar with whatever firmware you're currently using and don't save your models that you may have set up. Back them up, of course in the Variax Workbench, then you can re-load them after the re-flash. The firmware reload wipes out all of what you have in the guitar and sets everthing back to the factory defaults, including the alt tunings, I believe. I just did the firmware upgrade from 1.81 to 1.82, and saved my special models. The update went fine, took about 20 minutes to complete, so be patient.
      Good luck,
      Dave
