1689 Views 17 Replies Latest reply: Sep 10, 2012 4:57 AM by karabovc RSS
lowyaw Just Startin' 215 posts since
May 5, 2010
May 29, 2012 7:07 AM
What's your FRFR rig? HD500
I played several gigs with a FRFR setup - namely, HD500 left XLR into powered Biema monitor, right XLR - house mixing board > FOH
it still kinda depends on the venue, but somehow it was easier to get along with, then a regular tube amp - for cover band gigging, when you need "swiss army knife" kind of setup. it also surprised me taht even heavier tones - we did some Nickelback, and Rasmus, and Green Day - were convincing. So, i'll use it as an excuse to stop hauling my Mesa halfstack or renting smaller amps. What I obviously have to do, is to invest in a FRFR monitor.
What are my options? I am considering either HK Audio Pro112MA, or Mackie SRM450
anything else worth looking at? treble control is welcome
  • Karl_Houseknecht Expert Line 6 User 3,732 posts since
    Jan 25, 2007
    May 29, 2012 7:09 AM (in response to lowyaw)
    Re: What's your FRFR rig? HD500
    Avoid the SRM450V2 like the plague.  They are not the same monitors they used to be.
    I picked up a QSC K12 recently.  FANTASTIC.  I'd swear it was a 15" in there for the low end I'm getting, and yet it is very faithful to what's coming from the FOH.
  • daveschutt Just Startin' 280 posts since
    Sep 8, 2008
    May 29, 2012 12:20 PM (in response to lowyaw)
    I was in the same boat a while back.  I was playing mostly direct to PA and I found a few things that helped get consistent tones.  1. I purchased a $12 XLR Y-cable and that seemed to bring the fullnes back to some of the patches and I didn't have to worry about how they were panned going out of one XLR to the board. 2.  I bought an EV exp112 powered speaker.  It was at the right price point for me about $500 and had  few feature I really liked.  That was I could have 2 inputs and blend them right on the speaker so if I want to just goof around I can hook up a mic and plug in my guitar rig or acoustic I could use it as a basic PA.  I can also blend a band mix with my rig if I want and tweak my monitor mix there on the unit.  It sounds very good, has 1000 watts of power and has gotten very good reviews.  I'm looking in the near future to get a second and a powered sub so I can have a fully functional PA based on that series of speakers. Highly recommended!
    • jasonbogen Just Startin' 357 posts since
      Sep 24, 2007
      May 29, 2012 1:09 PM (in response to daveschutt)
      I have the EV ELX112P as well for my PA, but have tried it as a monitor for my HD500 and highly recommend it.  Check americanmusical.com for "B" stock at $479.
      When I was running FRFR before I got my DT25, I used a Roland KC-550 and loved it.  I would definitely suggest trying that out as well if you want an amp behind you.
  • Rewolf48 Just Startin' 133 posts since
    Aug 9, 2010
    May 30, 2012 4:48 AM (in response to lowyaw)
    I have a pair of FBT MaxX 2a that I got as a second hand bargain on ebay. They work great with the HD500 especially as monitors and the JTV Acoustic sounds through them are really impressive.  I spent ages looking at what is out there trying to work out what price point I could go to, so when I saw them on Ebay at well under normal selling price I didn't hesitate and I don't regret it one bit.
    There is a fairly interesting powered speaker shootout here http://www.acousticguitarforum.com/forums/showthread.php?t=180188
      Aug 9, 2010
      May 31, 2012 5:31 AM (in response to lowyaw)
      I haven't tried them - I do have a published review of 10" speakers that incldues the ART 10a, JBL, Mackie and my FBTs.
      http://www.fbtusa.net/files/Test_Report_10inch_Pow._Speakers_Tools_engl1.pdf
      As it is hosted by FBT you can probably guess the result.
      Personally I don't think that you need a 12" for guitar - the extra low end just doesn't (or shouldn't) be present in a guitar signal in a live environment unless you like fighting with the bass player.
      Whatever decision you do make (and it took me ages) I would suggest that you make sure that whatever you do get has some sort of tone control - as the HD doesn't have a global EQ you need to tune the sound to the room by either a) changing each patch seperately or b) changing after the HD.  A powered speaker without an eq doesn't allow you to do this without an extra bit of hardware.
  • Leftzilla Just Startin' 245 posts since
    Jan 25, 2007
    May 31, 2012 8:27 AM (in response to lowyaw)
    I personally use a Behringer 45 watt Kybd amp as my monitor onstage.  In one of my bands I send the quarter inch right directly to the board and left feed to the amp.  In the Prog band where we run stereo I send the both headphone out to the Behringer and then the quarter inch outputs to the mixing board panned appropriately.
  • artist1354 Just Startin' 5 posts since
    Mar 13, 2007
    Jun 1, 2012 8:55 AM (in response to lowyaw)
    QSC K-10.  Fantastic tone and plenty of volume.
  • berkleegrad Just Startin' 27 posts since
    May 12, 2007
    Jun 2, 2012 5:15 AM (in response to lowyaw)
    +1 for EV LiveX ELX112P!
    While it doesn't have an on board EQ, it does have a flat/mid cut EQ switch.
    PLUS, the output link can be used to pass signal to the FOH. This is handy, if you are connecting out of left 1/4 inch MONO on the HD and wish to pass that mono signal also to the board.
    Tweaking/creating your patches around 85dB will help you avoid much of the Fletcher Munson loudness issues and may allow you to dial out the 'too much' tweeter top end. If it sounds good in your FRFR then most likely it will sound good in the mix... Or at least you have given the sound tech something decent to work with ;)
  • mdmayfield Just Startin' 353 posts since
    Feb 24, 2007
    Jun 3, 2012 11:30 AM (in response to lowyaw)
    I own a K8 and like it very, very much. In the pop/rock bands I've played in, I've been totally satisfied with it, even when using it as my only amplification when I haven't been able to plug into the PA. It might not be quite enough for a crazy loud metal band, or maybe it might be... I've never run into its limits, so I don't know what its limits are.
    If you use it as your only amplification, I suggest putting it on a speaker stand close to ear level.
    Unless you use crazy low drop tunings, the K8 also has more than enough bass for a guitar in a band context. If you use a 12 or 15-inch speaker and crank the bass, it could step on the bass player's territory & make the overall band sound muddy.
  • sinistralx Just Startin' 18 posts since
    Nov 22, 2007
    Jun 7, 2012 3:13 PM (in response to lowyaw)
    I picked up an Atomic Reactor FR cab - 50watt tube power amp. Has XLR thru and a seperate tweeter attenuater. have found it to be a perfect setup. i can now swap out between electric and acoustic. Extremely punchy. Works a treat
  • karabovc Just Startin' 2 posts since
    Nov 8, 2007
    Sep 7, 2012 2:25 AM (in response to lowyaw)
    Hi guys. I've read all the coments, but i have a little bit different problem. I want to connect my pod HD 500 XLR outputs stereo to a PA and simultaneously to use the unbalansed outs to put in something for stereo monitoring on the stage. Is this possible, and how to do this?
    Thanks.
