512 Views 10 Replies Latest reply: May 31, 2012 3:51 PM by Nirvan93 RSS
Nirvan93 Just Startin' 8 posts since
Dec 19, 2011
May 29, 2012 2:08 PM
Bad quality with POD Studio GX
Hi
I saw many movies on youtube with pod farm and other amp simulators, and tone of other people is avesome but mine is terrible.
I don't know what is wrong, maybe guitar/cable or pod?
There are some samples:
http://www.mediafire.com/?riuwui76niqx1s6
http://www.mediafire.com/?b1d6ut1aul1dolh
http://www.mediafire.com/?kc3o63hhjko7aqc
http://www.mediafire.com/?ibzjic91m234tuh
http://www.mediafire.com/?95qccrh2xfy2lka
I used presets from pod farm as names of files.
It will be good if anyone send they sample with preset from pod farm and give tab and I will record the same for comparison.
I have POD about half-year and I am not satisfacted I want to record guitar in good quality but i can't do it with my pod.
  • hulbert Iknowathingortwo 375 posts since
    May 12, 2011
    May 29, 2012 8:27 PM (in response to Nirvan93)
    Re: Bad quality with POD Studio GX
       I have just tested those presets myself, and they aren't what I personally would like. I don't really like the sound I get from them either. I use my own settings when I use pod farm.
    One thing I wondered. Are you using old strings? Also, seems like your drop d tuning? is that right?, so some bits might sound a bit diff. I don't have mine on drop d, so couldn't get down that low to test, but anyway, it depends on what type of sound each person wants. Sometimes I want some big distortion - others clean - sometimes just a nice smooth overdrive etc.
    Are you using the neck pickup mainly? Maybe you could try tweaking the 4 band eq. I find that the eq is needed on pod farm for sounds I want.
    Here is one that I'm not totally in love with yet, but it was just one of my own that I tweaked the other day for using with a certain pickup. Also, it depends on what you are hearing it out of. I am using stereo's speakers. This setting sounds maybe a bit high pitch in tone, but on others' speakers it might not.
    Here are my settings for this one I am just using just now:
    Global gate off
    -58 noise gate thresh.
    4% decay on noise gate
    comp. -20 thresh and gain 0
    screamer 27 100 50
    Solo 100 head 14 53 48 60 74 100   (less high with 58 48 44)
    4 by 12 brit celest t-75s with room at 100 and 421 dynamic mic
    4 band eq at A -4.7 50hz
    B 9.5 100hz
    C -3.8 550hz
    D -5.6 9.0khz
    cavernous reverb all at 50 - if you want reverb
    It seems to be 'light' enough to be useable with single coil pickups and humbuckers.
    I haven't got on mediafire or anything to upload audio except youtube, so haven't put an audio file up.
    God Bless,
    David
        May 12, 2011
        May 30, 2012 4:37 AM (in response to Nirvan93)
        Hi again,
          Are you using single coil pickups or humbuckers? Really big distortion can make single coils sound fuzzy a bit.
        The version I am using is pod farm 2.50 with no packs.
        I think you will probably find a sound you like if you try the different amps and distortions and try tweaking them a bit. I just had a little test with the 2nd last preset you had and I found that with a recording of power chords I had, it made it a bit clearer  when I changed the amp to Line 6 Spinal Puppet and turned the volume up a bit to make it the same volume, but this recording was done with a humbucker. It may sound a bit muddy if I used it on a single coil pickup. I usually use my humbucker for a lot of distortion and then often switch to single coil for clean or not as much distortion/overdrive.
        If I use a lot of distortion with a single coil, I usually turn the  gain down a bit so that it isn't that fuzzy sound.
        I normally use the solo 100 head but I used to use the Line 6 chemical X a bit.
        Hope you get the sound you are after,
        God Bless,
        David
      May 12, 2011
      May 31, 2012 2:11 PM (in response to Nirvan93)
          I listened to your last sample with headphones, and yes, your powerchords sound great!
      Humbucker pickups are great for lead too.
      You don't need to buy another guitar (unless you want to get one)
      Humbuckers will give a strong, powerful lead sound. Single coils cannot do this very well you are using lots of distortion. Single coil pickups are good, but single coils don't really sound good with "high gain" - I mean like if you use a lot of distortion/ gain, the single coil guitar will sound a bit fuzzy and not very clear.
      If I use a lot of gain/distortion, I always use humbuckers. I think some single coils can handle the high gain, but most are made for less distortion.
      If you play things with less distortion, then humbuckers or single coils are good.
      They both have their different sound - both are good.
      If you want lots of distortion though, I would use humbuckers - for lead and chords.
      Basically, if I play 'clean' or soft, gentle stuff, I might use my guitar's single coil sound ( but sometimes I prefer the humbucker sound for this too), but if I want to play big distorted stuff, I use the humbucker. I use the humbucker for lead and chords.
      What amps and that have you got in 2.51? I think it should have the 4 band eq or some eq.
      God bless,
      David
          May 12, 2011
          May 31, 2012 3:17 PM (in response to Nirvan93)
          Hey, well done! Sounds good!
          Its not my style of music, but you've done really well!!
          I think the lead tone fits in that mix really well.
          What distortion pedal in pod farm do you use, or do you just use a pod farm amp?
          I usually use the screamer, but the spinal puppet amp is good with drive on full with no distortion pedal, or at 50 if you put a screamer in front of it.
          Another thing I have found. If you use a screamer etc., I put the input of the screamer down lower, and turn the gain of the screamer up. I find that if I have the input and gain both up, I get a kind of fizzy sound.
          Also, maybe try the Line 6 - 4 X 12 treadplate cabinet or 4X12 Line 6 cabinet.
          God bless,
          David
