300 Views 7 Replies Latest reply: Jan 3, 2013 2:35 PM by nuser101 RSS
killmodell Just Startin' 4 posts since
Oct 28, 2008
May 29, 2012 4:40 PM
Just got a Spider Valve MKII 112 -- First I loved it...
Now, not so much.
I received this amp last week for Father's Day. Played it a little through the week but not much. Loved the tones.
Immediately purchased the FBV Express and started messing with the presets a little.
I have discovered that every preset you load always comes with its own volume envelope and I am having a hell of a time switching between rythym and lead with any kind of move that looks halfway smooth... I have enough trouble worrying about the multitude of other things I'm responsible for on a tune without having that headache.
Now, I am writing this after trying to tweak some downloads just so I can practice with this monster tomorrow night and the switch dies. Nothing. It will download the presets when you load up SpiderValve Edit but nothing else. No lights. Just a click when i plug in the USB.
All's I can say is I went from loving this amplifier to being pretty damn happy this didn't die on me during a gig.
I got this from Guitar Center and apparently I get 30 days to drive this amp.
If I could afford two amps, this would be one of them. But I can't. So unless I am doing something terribly wrong, I wouldn't dare gig with this thing right now...
Does anyone else have problems with the volumes between presets? Is there a RESET switch on this Express pedal?
Ken
Toledo
    Dec 22, 2006
    if you were connected to spider edit, it won't control the amp...
    it can't use USB and control the amp at the same time only one or the other.
    also keep in mind that the FBV is just a dumb controller... it doesn't do anything more than control the amps capabilities.
    you can also adjust the volume and resave the tones as well to level them a bit...
    you'll want to adjust the channel volume and then save...
    after you do that the master volume will raise and lower all tones at once... to fit the situation/venue etc.
    for the most part you really won't mess with the master much... the channel volume should be most of what you use to level tones.
  • nuser101 Just Startin' 178 posts since
    Jan 24, 2007
    Get one of these and put it in the FX loop. http://omnisonicvolumebox.com/  I have a Fender HRD, which is notorious for having two volume settings: ZERO, MELT YOUR FACE. This makes it manageable at a cost of $20. It is not an attenuator, just a pot to control the level fed from the preamp to the amp, which is why you put it in the FX loop.
