199 Views 3 Replies Latest reply: Jun 6, 2012 6:43 PM by hulbert RSS
pierrotlcf Just Startin' 2 posts since
May 7, 2012
Jun 6, 2012 3:36 PM
(SOLVED) Pod Studio GX noise
I recently got a problem with my pod studio GX. Suddenly all my amps got a lot of noise. Much more than it used to be. I tried on a mac and a PC but the problem remains the same.
I joined an mp3 file with an example of what I can hear using a 2002 Angel P-Ball. If I turn of the amp I can't hear the noise anymore (in the end of the clip).
I'm afraid it's a problem from the GX itself since my configuration stayed the same and the noise just began one day.
Should I return my device? Does anybody knows where this problem comes from?
Thanks,
Pierre
  • hulbert Iknowathingortwo 375 posts since
    May 12, 2011
    Jun 5, 2012 4:58 PM (in response to pierrotlcf)
    Re: Pod Studio GX noise
       That sound is identical to what I get with my pc speakers. My wire has been moved about too much and it has been damaged. It stops when I move it certain ways.
    If the noise stops when you turn the software amp off, then I suppose its not that though, because it should still stay noisy.   - but if you haven't, maybe try moving the wires.
    If its when the amps are on, then it makes me think that its some noise getting in, and the increased gain of the amp or pedal before the amp is making it hearable.
    I'd be interested to know if you have any noise gate on and if turning the threshold up, cuts the noise at all.
    If it does, then it makes me think its some kind of noise getting into the guitar cable or the GX or usb cable. My first guess would be the guitar or usb cable.
    The guitar cable could have got a bit damaged.
    Also, its possible someone nearby is now running something which is sending out interference to your guitar's pickups or cable. Also, its possible this goes through the electrical outlet too and this can get right through to your speakers. I get this happening a few times every day. I don't know what it is but some noise affects my computer, stereo, radio etc. even when they are only on standby. I would look at that last though and get an electrician to see about that. Its more likely to be cables or connections somewhere.
    Could you test it in another part of the house or try moving the guitar?
    Does the noise happen when the guitar is being played or when the guitar isn't plugged in?
    God Bless,
    David
