Jun 20, 2012 10:29 AM
HD 500 Edit Reassigning Effects to FS
Like (0)
Hey gang- lots of great threads in here, spent a lot of time browsing before making the purchase of the 500. Really helped me make an informed decision, many thanks.
I'm sure I'm missing something simple, but take for example I drag an effect to a different place in the chain in the upper window, how do I reposition it in the lower window to a new FS? Is there some way to "gang sync" this? I tried to grab it, right click, etc and only managed to accidentally edit values.
In HD500 Edit (which I presume you are using since you talk about dragging) there is a tab called Controllers. This is where you make the footswitch assignments. IN the top left field, labeled Model, select the desired FX. Then in the filed immediately below, labeled FS Assign, assign the FX to the desired FS. The assignment of all FS is visible in the FOOTSWITCHES pane, below the CONTROLLERS pane.
Don't forget to use the SEND SELECTED command in HD500 Edit if you want to load/save the changes to the HD500 device. Otherwise your changes will be lost as soon as you close the HD500 Edit program.
Don't worry about the vertical order of the effects on that first screen in HD Edit. It does not relate directly to the footswitch order. The footswitches get assigned to effects in the order that you add them initially, by default, but you can change that later from the 'Controllers' screen.
Check out my post here for more details and pics --> http://line6.com/support/message/374740#374740
Silverhead pipped me to the post while I was typing ![]()
Fantastic gentlemen, thank you!
an additional note to jimsreynolds in the fx edit screen even though they wont be in order vertically as they are in the picture window when you scroll over a particular effect or blank box (no effect yet chosen), the proper vertical fx box or block will light up so you can see which one it is and the edit parameters for that effect.
