383 Views 6 Replies Latest reply: Sep 4, 2012 3:47 AM by rucademoura RSS
eklynx Just Startin' 23 posts since
Apr 16, 2009
Jun 26, 2012 1:18 PM
iPad Control
Looks like you'll have to buy a USB WIFI adapter to control the mixer via iPad.  Will that be available at release or will we have to wait a bit for it to come out?  How much will it cost?
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Jun 26, 2012 10:42 PM (in response to eklynx)
    Re: iPad Control
    Wi-Fi dongles are a common item and available now.  They cost about $25-40. We will post a list of supported units when M20d is released.
    Oct 13, 2008
    Aug 7, 2012 11:12 AM (in response to eklynx)
    Re: iPad Control
    Officially supported Wi-Fi dongles are: EnGenius EUB-9801 and Linksys AE1000
    If I were doing an install of the mixer I would use an external router.  That requires a USB to Ethernet cable and a router of course.  Approved cables are the Apple USB - Ethernet cable and the Trendnet TU2-ET100. Wi-Fi dongles are not very powerful and are subject to interference from other Wi-Fi that may be present.   I would recommend using a router that provides 5Ghz Wi-Fi and switch off the 2.4G internally.  Using an external router also gives you options for locating it better with respect to line of sight or even remote antenna options.
        Oct 13, 2008
        Aug 7, 2012 3:02 PM (in response to eklynx)
        Re: iPad Control
        The way this works is currently there is only one driver that is supported.  That driver supports a chipset (of which the approved units operate with).  The AE2500 does not use that chipset so it will not work.  We are investigating other drivers with the goal to be able to support other units in the future ... but we don't know just how this will work out for now.
        The EnGenius EUB-9801 works significantly better than the Linksys unit that is now discontinued and I would recommend getting that unit if you wish to use a dongle.
        A quick google search shows it sold online at Amazon, Fry's, CDW, Best Buy, Comp USA, J&R, Newegg, Tiger Direct, overstock and even Walmart ( although the price can vary a lot)
  • rucademoura Just Startin' 30 posts since
    Apr 12, 2012
    Sep 4, 2012 3:47 AM (in response to eklynx)
    Re: iPad Control
    EnGenius working fine here! No problems till now!! Perfect!!
    https://www.solwise-secure.co.uk
    you can get one at this site!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
