100 Views 1 Reply Latest reply: Jul 7, 2012 5:02 PM by Crusty_Old_Rocker RSS
Jephys Just Startin' 10 posts since
Feb 9, 2012
Jul 7, 2012 4:21 PM
Sending POD HD directly to the amp effects return. Settings?
I have a Blackstar HT-5r and I want to use the POD HD500 without my the Blackstar preamp coloring the sound. To do so I will run the output of the POD into the effects return of the amp. Questions for the experts:
1-Which should be the Output settings?
2- How should I set the "1/4 Out" from the panel of the POD?
My guess for 1 is Combo Power Amp and Amp for number 2 but please chime in.
Thanks
  • Crusty_Old_Rocker Expert Line 6 User 3,096 posts since
    Jan 24, 2007
    If your amp has an open back "combo" style cab then set it to combo, if it's a closed back cab, go with the stack output setting.
    But experiment, some people actually prefer going with the Studio Direct option.
    You'll probably want to use the full amp models as your Blackstar power amp only has one topology.  But you might like to try mixing the modelled preamps with the Blackstar power amp.  It's really up to you.
    You can also try selecting no cabinet in you patches to remove the cabinet modelling from the tone.
    Cheers,
    Crusty
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
