536 Views 6 Replies Latest reply: Jul 9, 2012 12:27 AM by jimsreynolds RSS
anelson86 Just Startin' 4 posts since
Feb 11, 2012
Jul 7, 2012 7:01 PM
HD500 expression pedal not working properly
So I have an HD500 that is about 8 months old.  This week I started to notice that the expression pedal is not properly sweeping through the full range.  What is particularly frustrating is that it often will only go from about 0-20%, so I am stuck in the middle of playing and can't get my volume pedal to go above 20%.  Adding to the odd behaviour is that after being powered off for a few hours, when turned on the pedal will work normally for 2-3 minutes.  After I have used it for a few minutes the problem shows up.
I did the calibration procedure laid out in the document here: http://line6.com/support/docs/DOC-2223 When doing the step using footswtich C to check the scaled pedal value, I get 0 at the heel position, and then it will scale to about 60 and then jump to around 140 when I'm at the toe position.  If I set the pedal at a certain level and then leave it, the scaled value will not remain constant but rapidly jumps around to different values - faster than the LCD can resolve the digits.
Anybody have any idea what might be wrong or any troubleshooting steps to fix it?
Thanks!
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Jul 8, 2012 2:20 AM (in response to anelson86)
    Re: HD500 expression pedal not working properly
    If you are certain that you have followed the calibration sequence correctly then you could do what this guy dd and clean the sensor.  Beware of the potential warranty issues ... http://line6.com/support/message/350381#350381
        Jun 27, 43450
        Jul 8, 2012 5:04 PM (in response to anelson86)
        Not beyond the realms of possiblity.
        Suggest you re-flash (keeping presets) and then do a global settings reset and calibration.
        Bear in mind that if there is some kind of sticky goop on the sensor that the air-jet may not clear it.
