Jul 9, 2012 4:54 AM
Using Bass Pod XT Pro as an effect unit
Like (0)
Hello,
For a gig next month, I have a requirment to use my Bass Pod XT Pro simply as:
1. a chorus pedal
2. a distortion pedal
I have an FX loop on my GenzBenz Streamliner 900.
What would be the best way to set up and hook up the Pod to get the best out of the 2 effects I need to use?
Many thanks
Chris
Can anyone help with this question?
Thank you,
Chris
from the amp's effect loop out into the line level in on the back of the pod xt pro, then from the 1/4" analog model out of the pod xt pro into the amp's effects return. On the Pod, set up some channels with the effects you want but set the amp sim to none (off) and turn off a.i.r (cab emulation). and then set one channel as total clean (i.e. - no effects, amps or air). Ifyou have a pedal, you can use it like stomp boxes.
And that should do it! ![]()
hip63
Excellent, thank you very much indeed!
