297 Views 9 Replies Latest reply: Jul 12, 2012 3:03 AM by jimsreynolds RSS
fechart Just Startin' 74 posts since
Apr 27, 2012
Jul 9, 2012 6:06 PM
POD HD500 + Laney TT50 - 4CM - Need Help With Levels
Hello there,
I was buying a Marshall JVM 410C untill yesterday, but in the store they told me I would have to wait 6 months instead of 3... So I found a great deal with a Laney TT50, I bought it second handed for just USD 1.250 (here in my country the price of this amp, new, is USD 2290).
This amp has send/return connectivity, plus a MIDI function, as the JVM has.
I can´t explain how happy I was when I plugged my POD HD 500 straight to the Effects Return of the amp!!! It sounds really good!!! I was just tired of messing around with my Fender Blues Junior III and not getting good results, but I suddenly breathed!!!
I plan to connect the TT50 to the POD HD500 by the 4CM+Midi, so i´ts veeeeery probable that I´ll be bothering with some questions about that in the forum
Cheers!
PS: anybody having the TT50 out there?
    Dec 22, 2006
    Jul 9, 2012 9:59 AM (in response to fechart)
    Re: POD HD500 + Laney TT50
    great, always nice to hear when someone's tone takes a turn in the right direction.
      • jimsreynolds Power User 2,227 posts since
        Jun 27, 43450
        Jul 10, 2012 4:27 AM (in response to fechart)
        I had that problem with my JVM - the 'real' preamps were much louder than the modelled one.
        The answer was to
        1)  Set the amp FX Loop Level to the lower one (-10dB)
        2)  Turn the Pod 1/4" Output to 'Line'
        3)  Turn all my patches way down, using the Mixer,  and then back up to match the 'right level'
        This effectively gives the Pod more gain at the output and therefore the ability to drive the Power amp properly using the Modelled amps.  The level mismatch between Pod output and FX Return is not an issue provided you turn your patch levels down so they are are at the level that you would hear if you were running the amp on its own.
        If you haven't already seen it, checkout my 4CM guide here --> http://line6.com/support/docs/DOC-2522.  I cover this.  Go with the 'Second' method, highlighted in blue.  Run through the whole thing, including patch construction, and let me know how it works out.
        Cheers
        JIM
              Jun 27, 43450
              Jul 10, 2012 1:56 PM (in response to fechart)
              Turning down the FX Send level is actually a bad way to go.  It seems that the POD may drop a few dB of gain between it's input and the FX Send.  In fact:  I boost the signal using a studio EQ before the FX Loop, as per my guide.
              Remember:  the name of the game with 4CM is to get the levels identical (or close to) the levels that you would hear if you use the amp on it's own.   If you end up overly boosting or cutting the signal then you will either clip or end up with tone suck.  The method and effects order that I describe nails these levels on my HD/amp setup and should work well for most setups.
              Make sure the mix control on your Laney is 100% up or the tone may sound weak and phasey.
              The Mixer should not suck tone if set right.  try setting up the 'real' patches as per my guide and then turning down the modelled patches using the mixer and volume knob to match the real pre-amps.
                    Jun 27, 43450
                    Jul 12, 2012 3:03 AM (in response to fechart)
                    On the JVM: I can control the Channel, FX Loop, Midi and Master Volume using the Pod and MIDI.  The Master volume has two selectable levels and you can choose between the two.
                    The rest of the controls are not programmable so gain, tone stack and channel volume are all analog and you need to dial them in.  Just the nature of the beast.
                    I think you would need a full Midi-programmable pre-amp to get the fine level of control over the amp controls that I think you are looking for.  My way?   Set the levels how you like them and memorise them.  Initially with the JVM I created a Laminate (too many darn knobs to memorise) but now I am happy to set general levels on the JVM and tweak them for the scenario/room.  In some ways this is better and easier to work with .... you don't want to be reprogramming your levels just before you start playing !!!
