116 Views 4 Replies Latest reply: Jul 15, 2012 5:30 PM by epiduncan RSS
epiduncan Just Startin' 6 posts since
Mar 24, 2011
Jul 14, 2012 8:32 PM
spider IV, POD xt 2.0 and shortboar express
hi, I'm looking for a PODxt 2.0 for reaching a sound near of In flames amp set up . I have a spider IV amp with a FBV MKII express contoller. Do it is Compatible? Do it is a good set up or do I most looking for something else? And if is a good set up do the wiring will be the FBV to the POD and finally in the amp ?
thank you
Perry
  • Mr_Arkadin Expert Line 6 User 2,379 posts since
    Jan 25, 2007
    Jul 15, 2012 10:09 AM (in response to epiduncan)
    Re: spider IV, POD xt 2.0 and shortboar express
    First we need to check what product you mean - there is no such thing as a Podxt 2.0. Do you mean a PODxt or a POD2.0 (two very different devices)?
    If you mean a PODxt then yes the FBV Express MkII will work fine.
    If you mean a POD2.0 then it depends upon the age of the POD2.0. Older models have the label "Pedal" written on the rear and cannot use the FBV range of pedal. If it is a later POD2.0 then the label will read "FBV Pedal" and you can use the FBV range of pedals in this version of the POD2.0.
    You cannot use one pedal to control the amp and Pod if that is what you are trying to do, although I believe some have experimented with splitting the cables, but I do not know if these attempts were succesful.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
