303 Views 12 Replies Latest reply: Jul 25, 2012 5:34 AM by fflbrgst RSS
poynt99 Just Startin' 32 posts since
Jul 24, 2011
Jul 18, 2012 7:00 PM
Spider IV EDIT Annoyance - AMP Selection changes effects
I have found something very annoyinig while using Spider IV Edit:
After I set up a preset with an amp and the effects I want to use, I would like to be able to change the selected amp to a different model, but the instant you do this, all the effects settings change as well. I want to change amplifier models to see how they sound through the effect and stomp chain I have set up. But I can't do this; you end up having to reset all the stomps and effects again. That could take hours and hours to do.
Why does the Line 6 gear do this???
Or am I missing something?
  • fflbrgst Power User 1,292 posts since
    Mar 6, 2011
    Changing the amp model automatically changes the other settings to those of that amp model - the model includes things like Gain, EQ, etc, so if those didn't change, you wouldn't be changing to that amp model!
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Here's a snip from the Spider FAQs on the product pages:
    Frequently Asked Questions
    What's manual mode?
    Manual mode (available in Spider IV 75, 120, 150 and HD150) is for players who desire a more traditional amplifier experience.
    •  Out of manual mode, choosing an amp model dictates the settings of the other front-panel knobs (EQ, Drive, FX, etc)
    • In manual mode, choosing an amp model does not dictate the settings of the other front-panel knobs.
      Mar 6, 2011
      OK.  Spider Edit is the software you use on your computer to make tones, then load them into the amp through your FBV controller.
      So maybe you mean you are in Edit Mode in your amp, using the small LCD screen?
      Either way, you're not in manual mode when you do this.
            Mar 6, 2011
            That's the way it works!
                Mar 6, 2011
                Again, do you mean Spider Edit (software on your computer) or the edit mode on your amp?
                If you want to use a Manual Mode sound, then add FX (or not),  you can select it, then save it to a User Preset location, then access it through the Edit Mode.
                This is how I have set up my patches for use when playing with my Beatles tribute band.  I first used manual mode to come up with a good Clean setting for use with acoustic guitar, then saved this to a User location.   Then I selected the Class A Red manual mode, adjusted tone as needed, and saved this as my usual rhythm guitar Vox sound.  I then edited this sound further adding more gain and volume for lead guitar parts, and another patch with more electric trebley sound for other rhythm parts.
                  Mar 6, 2011
                  No, you have to understand that Spider Edit is not accessing the amp, except when you move patches from the amp to Spider Edit , or from Spider Edit to the User Preset locations in the amp.
                  So, if you want to access Manual Mode souunds, save them to User Preset locations, then move them over to SPider Edit (and save them there), then you can manupilate/change them, save them under new names, and move them into the amp.
