131 Views 2 Replies Latest reply: Jul 30, 2012 6:35 AM by TheRealZap RSS
javi_bassist Just Startin' 11 posts since
Sep 10, 2011
Jul 30, 2012 3:36 AM
HD 400 and lowdown410
Hi!
I recently purchased the line6 HD400 and i need a cab. I want to buy the line6 cab lowdown 410, but i saw it works at 8ohms and the head cannot work at 8ohms, only at 4ohms. Could i use the head with a 8ohms cab? I need to know because i will play a show and the other band will lend me their bass cab and it works at 8ohms and i don't want to make the cab burn
To sum up, can i use a single 8ohm cab (like the lowdown cab) with the HD400 head?
  • kweatherhead Just Startin' 26 posts since
    Oct 5, 2009
    Jul 30, 2012 5:46 AM (in response to javi_bassist)
    Re: HD 400 and lowdown410
    YES, you can certainly use the 410 (8 ohm) cabinet and it will work just fine.  HOWEVER, you will not get the full power of the HD400 since you are running at  8 ohms rather than a 4 ohm load.  You could therefore, run the HD400 with two (410 or equivelent) cabinets or a single 4 Ohm cabinet to achive the rated power output of the HD400 head.
    Keith
    Dec 22, 2006
    Jul 30, 2012 6:35 AM (in response to javi_bassist)
    using a higher number ohm is not generally a problem... you just don't want to go lower.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
