Aug 1, 2012 12:14 PM
UX1/Ableton problem
Like (0)
Hi guys,
I know there are a lot of similar discussions on this topic, but mine problem is a little different. I just can't record the sound of guitar in Ableton via the VST plugin Pod Farm 2. I can actually hear the sound of guitar through Ableton, but when I want to record it, no sound is captured... here are some pics about my preferences and so on...
Somehow I had to put the Monitor on "IN", because on "auto" and "off" i couldn't hear the guitar sound.
So guys, I will be happy if you can help me.
I do not use ableton.
But you need to connect your speakers the the UX.
Are a track to record and select the sends from the UX.
You can capture the wet and/or dry guitar. In POD Farm standalone set up what sends 1 thru 4 send.
You do not record with the plug-in, you record either the wet and/or dry sounds with POD Farm (or just pass the dry signal without launching PF).
The plug-in is applied to recorded tracks and you must launch PF from within ableton to access the plug-in.
