Aug 13, 2012 7:18 AM
HD500 EX-2 and Wah ?
Like (0)
Can EX-2 be calibrated? I use the Line 6 Mission expression pedal, which is great by the way. Nice heavy duty pedal. I used the pedal with the shortboard and Flextone before I got the HD500. There was a way to calibrate the second pedal on Flextone setup, but I've been reading through the literature and forums and haven't found anything on the HD500.
Also, whenever I insert a wah into a patch it changes the tone of the patch even when I have the wah in bypass. Normal behavior? It usually sounds like a little noise is included when I insert the wah.
I have the same expression pedal. It works great! When you have the desired effect highlighted in the edit mode, quickly double tap the move button to open up a window that shows what parameter you want the expression pedal to control. Is that what you mean by "calibrate"?
Hey Matt. I'm not looking to change the parameters. I'm looking to set the sweep of the pedal. So that way the board knows when it is at heel or toe position. You can do it for the EX-1 on the board. Press left on the directional pad while starting up to get into the calibration mode. The directions are in the manual. Look them up before you try it or you can mess up the sweep of the pedal.
Oh right! Personally, to set up the sweep for the EX-2 I go into the edit mode I explained earlier and adjust the min value (heel) and the max value (toe) using knobs 3 and 4 for the effect I choose. I've noticed some effects will already be at max value before the EX-2 pedal is at toe down postion. I don't think there's a way around that.
Hi guys
How to Add Pedal Wah Or Pedal pan And Both t preset in Hd 500?????
Please Help me THX
Sasan try this ... http://line6.com/support/docs/DOC-2720
