1036 Views 14 Replies Latest reply: Feb 11, 2013 1:57 PM by cam_shand RSS
hedeon Just Startin' 3 posts since
Jul 26, 2012
Aug 14, 2012 5:51 AM
POD 2.0 ==> PC
Hi. Yes, I know, it looks like it was here thousands of times, I've ready it but still can't connect my recently bought old POD 2.0 (the one with PEDAL mark) to my PC.
Now, I play guitar ocacsionally only, I have never used such sophisticated tool like POD before, never had any expirience with any MIDI devices before, and I don't have sound enginiering degree.
All I want it to do is to push some presets, or patches downloaded from Line6 Custometone to my POD 2.0 ( I should have buy one of POD pocket really...). That's it.
I have bought that cable MIDI to USB, and it's driver seams to be installed corectly.
Now, when I launch Line6 Edit it doesn't find my POD. All cables are connected. I have tried to plug MIDI cables in all ways, IN-IN OUT-OUT and IN-OUT OUT-IN.
Have tried different USB ports in my PC (BTW it is Windows 7 64bit machine with intel i7 and 16GB of RAM)
That MIDI - USB cable has something in the middle, with three LED's. When I plug cable to PC a LED above MIDI lights up, but no matter what I do, LEDs for IN and OUT are always off.
So, what shoul I do. My POD dosn't come up in MIDI devices, when I hit 'add' a new window pops out 'add device' with options:
MIDI IN PORT:          USB2.0-MIDI
MIDI OUT PORT:    Microsoft GS Wavetable Synth
                              USB2.0-MIDI
                              USB2.0-MIDI
DEVICE:               plenty to choose from, along with them POD 2.0
No matter what I choose here my POD picture always comes up wit yelow question mark on it, and I have no connection.
Please can someone tell me what I am doing wrong here?
Thanks for any help.
That is my adapter and its LEDs
https://lh6.googleusercontent.com/-hvHapbTBPYA/UCpFhcnjRbI/AAAAAAAAOX0/h6Bg50s5DYU/s1095/IMG_20120814_133229.jpg
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Aug 14, 2012 6:41 AM (in response to hedeon)
    Re: POD 2.0 ==> PC
    Have you downloaded the POD 2.0 driver form here?
    http://line6.com/software/
    Feb 20, 2007
    Aug 14, 2012 8:34 AM (in response to hedeon)
    Re: POD 2.0 ==> PC
    My apologies, there are no drivers for the POD 2.0.
    It sounds like you are doing everything correctly. (IN-OUT OUT-IN.)
    Did you check the manufacture's site of the MIDI-USB device to see if they have newer drivers?
    Can the newest version of Monkey see it?
    You can also contact Line6 via a ticket or by calling.
    http://line6.com/support/tickets/add.html
    Line 6 - North America
    Line 6, Inc.
    26580  Agoura Road
    Calabasas, CA 91302-1921
    Main Phone#: (818) 575-3600
    Main Fax#: (818) 575-3601
    Customer Service hours are 8am - 5pm M-F Pacific Time
    Press option 3 for Customer Service
    Our busiest hours are from 11am to 2 pm.
    Line 6 - Europe
    Line 6, Inc.
    The POD
    Clifton House
    Butler's Leap
    Rugby, Warwickshire
    United Kingdom, CV21 3RQ
    Telefone: +44 (0) 1788 566 566
    Fax: +44 (0) 1788 566 529
    Technical Support: +44 (0) 1788 566 555, Mon-Thurs 9am – 5pm GMT and Fri 9am – 4pm GMT
  • marginwalker Just Startin' 1 posts since
    Dec 29, 2009
    Sep 17, 2012 12:43 PM (in response to hedeon)
    Re: POD 2.0 ==> PC
    Hi
    Did you ever get this resolved ? I am having the same problems. I just can't get Line 6 Edit to see the POD. I have same MIDI device as you & I know the POD is sending info, as when change any of the settings on the POD the LED for MIDI Out flickers, at it's sending info.
    Any help would be appreciated. I know this product is getting on a bit but I thought it would be useful to be able to connect the POD to the computer to "tweak" it.
    • toneman2121 Gear Head 1,985 posts since
      Oct 15, 2006
      Sep 17, 2012 1:24 PM (in response to marginwalker)
      Re: POD 2.0 ==> PC
      firstly, i believe midi to usb devices have IN and OUT indicated in the plugs. they are to be plugged in to their corresponding inputs. that is IN to IN, OUT to OUT. not, as you would fx send and receive where send from one device would connect to the input of the other and receive to the output. secondly, there have been issues regarding midi to usb devices other than m-audio midisport uno.
      • peterbennett26 Just Startin' 17 posts since
        Mar 25, 2009
        Jan 1, 2013 8:16 AM (in response to toneman2121)
        Re: POD 2.0 ==> PC
        Sorry toneman but the usual midi connections on my keyboards etc. on the device's socket named 'out' you insert the plug named 'in', and vice versa. They do not comunicate if you put them as you suggest in to in and out to out, but anyway it's no hardship to switch them round and check this if the leads are marked up differently, each line is a one way street. From the device's 'out' to the receiver's 'in' etc.
  • splinteredmind Just Startin' 1 posts since
    Dec 12, 2012
    Dec 22, 2012 12:08 PM (in response to hedeon)
    Re: POD 2.0 ==> PC
    also i have the same problem. is there nobody from line 6 reading this?? we have spent enough money on your damn products, there should be easier way to get them to work correctly!!!!!!!!!!!
  • Vorpymaedes Just Startin' 1 posts since
    Dec 26, 2012
    Dec 31, 2012 8:40 AM (in response to hedeon)
    Re: POD 2.0 ==> PC
    I think i've tried damn near everything to make the POD 2.0 MIDI connection work. I have the most recommended interface, all the latest drivers and programs. It still won't work. when i attempt to use it through Line 6 edit, first it tells me that the pod has "stopped responding". I go to the MIDI device menu and check all the right elements are selected. Then it seems to load the connection, when it goes "POD 2.0 is currently busy. Please wait for the opertation to complete". It's tedous to the point that i'm starting to regret my purchase of the POD itself, as the direct-in sounds are really poor compared to what some can achieve from downloading tones.
    I have updated the device on Line 6 monkey, but lately it has also let me down: "Failed to connect to selected Line 6 device using specified MIDI ports. (Code 800090007) the system failed allocation of memory"
      Mar 25, 2009
      Jan 1, 2013 8:43 AM (in response to Vorpymaedes)
      Re: POD 2.0 ==> PC
      Hi we are on the same path same problem, you can get the data lights to work (but unfortunately it will not help you with the communication problem. I reckon the underlying problem is that the Line 6 software is too flaky.
      Load up the freeware MIDI-OX  go into options and highlight your usb2 device in both input and output fields and also in the mapping windows. The click ok and twiddle a few knobs. you will see both lights light up and a stream of correct midi comunication data is logged. The problem is that Line 6 software can not similarly link up to the POD !!!! amazing a 986 kb program does it perfectly. I suppose with the recommended more expensive m-audio midi-USB interface device it is doing a lot of the communication job for the pod and its software. (Heck I've just discovered that pod users have been getting the same problem with that interface.)
      MIDI-OX is obviously more robust at getting midi devices to talk to it, even the the POD, incredible as it seems!!!
      Sorry tried to upload images but they are all 3MB each
        Mar 25, 2009
        Jan 1, 2013 8:31 AM (in response to peterbennett26)
        Re: POD 2.0 ==> PC
        Found a way to reduce size by using windows photo gallery and attaching them to an e-mail to myself. There's probably a more elegant way but it worked.1.jpg
        There's the evidence that the computer can see/comunicate with the pod through these cheapo specials, it is Line 6 edit that cannot !!!
        NB each of the above lines is generated when I turn a knob on the pod. the bottom set of lines are generated when I go through the presets using the up and own buttons.
        The guy who sold me the cheapo midi-usb interface gizmo is giving me a refund so I'll bite the bullet and get the recommended M-Audio but in another thread
        ooklathemok is even having the same issues with that expensive cable.
  • cam_shand Just Startin' 1 posts since
    Apr 12, 2012
    Feb 11, 2013 1:57 PM (in response to hedeon)
    Re: POD 2.0 ==> PC
    Hi, I have exactly the same MIDI cables and, a few days ago, had this problem.
    I switched the cables round (eg. the "IN" cable goes into the "OUT" one on the POD and the "OUT" cable goes into the "IN" one onm the POD). Then, once you're on the Line6 Editor, you need to go to the "MIDI devices" screen, this should pop up when you open the application. At the bottom of that, you need to click "add". A window should come up with 3 drop down menus. The first one should say "MIDI In Port:", select "USB MIDI interface" for that and the next drop down. For the third, leave it as "auto detect". Then click "Add".
    It should show a picture of a POD and say POD 2.0. If it doesn't, I'm afraid I can't help you.
    Hope this helps, send a message if you need anything else, this worked for me and i use the same MIDI cables.
    You don't need to have to download drivers for this, it worked for me as soon as I switched the IN and OUT ends round.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
