281 Views 7 Replies Latest reply: Aug 20, 2012 2:42 PM by tyrantmode RSS
tyrantmode Just Startin' 9 posts since
Jun 4, 2011
Aug 18, 2012 8:33 PM
HD500 won't global reset or calibrate pedal
Just received my HD500 (upgraded from a 400) and I'm having a great deal of trouble with it.
I immediately updated to the latest Flash and drivers from Line6 Monkey, and when I try to perform a global reset (left button while powering up) it won't do a global reset.
It WILL go into pedal calibration mode, but when I set the up and down positions to 100 and go to the scale sweet it won't read the pedal as going up or down.
Really aggravated, I was extremely excited about this upgrade and so far it's only been a big pain.
    • mazuwa Iknowathingortwo 371 posts since
      Jul 7, 2006
      Aug 18, 2012 11:40 PM (in response to tyrantmode)
      Re: HD500 won't global reset or calibrate pedal
      Sorry for asking this, but some people exchange left and right (<L - R>).
      It is also important to still keep the button pressed while powering on.
      Usually the HD500 will go into pedal calibration when holding the RIGHT button while powering on.
      Or do you mean it will do nothing holding the LEFT button, but will join pedal calibration mode when holding the RIGHT button (because you say it WILL go into pedal calibration mode....)?
      I guess you cannot do a proper pedal calibration before you haven't finished the global reset after a new firmware update.
      However, you can check if each button is o.k. Maybe the LEFT button doesn't contact.
      Easy way to check: Go to a preset and try to move the cursor left and right, which points at any fx block / amp.
      Other way: Hold down the RIGHT button while powering on to join Test mode, then move cursor to 2nd position (Buttons). Then Press VIEW button.
      Each time you press a button (a button = VIEW, SAVE, ENTER, MOVE, LEFT, RIGHT, etc.), the result should change from "0 0" to "1 1".
      Exit by powering off/on. By doing this you have nothing changed, just tested.
      The reason why the pedal position is not recognized might come from dirt underneath the pedal, like a little piece of paper.
        • jimsreynolds Power User 2,227 posts since
          Jun 27, 43450
          Aug 19, 2012 7:25 AM (in response to tyrantmode)
          Might be a hardware issue but worth doing some checks first.
          I take it you are following the recalibration process here to the letter --> http://line6.com/support/docs/DOC-2223
          Failing that: it could be a dirty sensor within the unit.   A few people have (carefully) opened and cleaned their sensor but be aware that it is almost certainly a warranty-buster.  Details are here http://line6.com/support/message/350381#350381
            • silverhead Expert Line 6 User 9,592 posts since
              Apr 1, 2009
              Aug 19, 2012 7:57 AM (in response to tyrantmode)
              tyrantmode wrote:
              Attempt to global reset... power on while holding left arrow, nothing happens, just boots up normally...
              I think that is normal - there is no immediate feedback that the global reset has been performed. You will be able to tell by viewing the Setlist names after it has started up. They will be changed to the factory resets. To test: use HD500 Edit to load a custom-named setlist into one of the User Setlist names. SEND the setlist to the HD device. Then restart while performing the global settings reset (hold down the left nav key). View the setlist you loaded earlier. You should notice that the setlist name has changed back to the default, but the presets within the setlist have not changed.
              If you can verify that the global settings reset is working properly, you may then consider whether to perform the sensor cleaning on the pedal interior. I did that and my pedal has calibrated perfectly ever since.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
