Aug 24, 2012 6:45 PM
Help: Spider IV 75 Screen issue, EQ screen
Like (0)
Hey Guys
My screen continues to change to the EQ settings for no reason, even if I change the presets it will still automatical change itself back to that screen.
If someone could give me a hand, it would be much appreciated.
Does this happen whether you are playing an instrument through the amp or not? It sounds like a control is 'waking up' as if it is getting moved. You may have a problem with one of the knobs or potentiometers a knob controls.
Have you tried a factory reset first? (Hold the A button in while turning on the amp)
I have the same issue. Doesn't matter if I'm playing or not - screen always shows the EQ settings.
So if you change your preset channel or switch to manual mode, it flashes the new info, then immediately changes over to the EQ screen? What happens if you activate the edit mode by pushing in the parameter knob, then turning it to other settings?
If it keeps popping back to the EQ screen, I suggest bringing it to an authorized service center to check it.
