4222 Views 29 Replies Latest reply: Feb 9, 2013 8:41 PM by thomasmorgan0205 RSS
orangekrushmn Just Startin' 6 posts since
Mar 21, 2012
Aug 25, 2012 11:14 AM
Rackmount Power Amp for POD HD PRO
Hey there,
I am currently aquiring a Pod HD Pro, and I was curious to see if anybody knew a wise power amp to use with it that is rackmounted as well.
It is being paired with a Randall RT412CX Cabinet, which is a 100w cab with an 8 ohm impedance setting.
Any help would be very much appreciated, because I need to make sure I can get the right power amp and not destroy anything.
Cheers!
Jerrod
  • hollis1003 Iknowathingortwo 342 posts since
    Feb 6, 2007
    Aug 25, 2012 12:40 PM (in response to orangekrushmn)
    Re: Rackmount Power Amp for POD HD PRO
    http://www.matrixamplification.com/
    These are being used with POD HDs and with Axe-Fx.
  • niall182 Just Startin' 10 posts since
    Apr 19, 2008
    Aug 26, 2012 3:09 AM (in response to orangekrushmn)
    Seriously consider Rocktron Velocity 300, its a 1u stereo (or mono) 300watt power amp, (150watt stereo or 300watt mono) designed for guitars...solid state and runs very cool...I've had mine for over a year, run it with a Digitech 2120 (soon to be replaced by a Pod HD Pro)...the thing sounds like a valve amp but without the hassle of valves or overheating or tube replacement or being 2/3u high! I gig in a pro band 2/3 times a week...never fails built properly, Rocktron make excellent product...got mine from Thoman on line...get the 300 nothing lower...by the way this is very very loud if you want it to be!
    Cheers
    • HDProJohn Just Startin' 38 posts since
      Feb 16, 2012
      Aug 26, 2012 8:42 PM (in response to niall182)
      Dude, there are tons of options... Matrix is all the new rage lately, while Rocktron is the other SS contender. Supposedly Fryette is designing a 1u to compete as well. For valve amps you got Mesa 50/50 (what I use because my buddy is lending me his even though I'm jonesing for something that doesn't color so damn much - I require studio and live patches), 2:50 and the 2:90. VHT has some that are regarded as the cat's ***, and even Carvin has one that's supposed to be decent. I know there are more, but these are off the top of my head. Really depends on which tubes you'd want to run too. Recently I saw Glasscloud and their guy was running 2 Axe ultras through 2 Crown PA amps...even though on the Matrix site he's endorsed. That'd be an option too.
          Feb 16, 2012
          Aug 28, 2012 1:26 PM (in response to orangekrushmn)
          Not to be a jerk, but you need to do some research if you are asking a forum which amplifier to buy according to impedence only. There are so many other variables that nobody can give you the "best" answer. Such as, will you be wanting to run a different cab for different style of sounds (hi-gain vs. clean, for example)? What style of music is it even for (doom/sludgy metal vs. djenty/progressive/rock/whatever-core vs. pop/country cleans would all get a different vote from me for tube choice)? Do you play in a balls loud band or are you a bedroom player? Like Jim Reynolds mentioned, will you ever be wanting to go FRFR and/or just output to the house PA? Are you happy with the emulated tube feeling in the Pod or do you want physical tubes? Get my point yet?
          Both of the amps you listed would work. The Crown would probably require a Speakon to 1/4" cable and could definitely overpower a guitar cab (I've only used them for PA applications, personally). The SS Carvin would work too; however, I'd be a bit worried if I was to purchase it because it doesn't have a fan. Go read for at least a week and figure out what you're shooting for and what you want to do with the Pod.
              Feb 16, 2012
              Sep 14, 2012 7:44 AM (in response to orangekrushmn)
              I'm in a similar group, here's what we do. Other guitarist (Axe II) and I run DI into our PA as well as using our cabs for stage volume and additional monitoring. We use a MBP with Ableton Live for all of the samples and click (imported from bounced PT10 session files). This way, the drummer doesn't have to use a brain to trigger anything. Also, I need to get my butt in gear and write a MIDI map for each song so that the Live file will change patches for me. Misha from Periphery has mentioned that they had quite a few hard drives fail on them and recommends a SSD for this machine. Of course, that depends on how much gigging you're doing. Just something to point out.
              Consider running an EQ pedal pre-Pod to give it some balls. Helped my FOH sound tremendously.
                  Feb 16, 2012
                  Sep 17, 2012 8:41 AM (in response to orangekrushmn)
                  Yes, you need an interface. How else would you get the sound from the MBP to the mixer? SSD = solid state hard drive. I already mentioned the benefit of running one.
                  I don't know what a minister system is or what you mean by needing a mixer for your minister. Are you playing in a church? Is your minister mixing your shows? I can't imagine BOO styled music going over well in this setting...
                  Likewise, I don't understand how you could be using a PA system without a mixer. So, my answer is yes, you need a mixer. I am also assuming that you're using wedge monitors. You'd need a mixer to select which channels to AUX out to your wedge mixes, set volumes for FOH and so on. Thinking you need to go do some reading on the basics of PA systems at this point before I tell you to go buy a $1000 worth of gear that you don't need because I can't understand what you're attempting to do.
        • davidb7170 Just Startin' 253 posts since
          May 3, 2008
          Sep 16, 2012 6:03 PM (in response to orangekrushmn)
          Hi -- thought I'd add my 2 cents. I was using a Crate Power Block 150 (150 Watts bridged, Class D digital amp, about the size of a loaf of bread, and about 5 or 6 lbs) for about 5 or 6 years, but just picked up a Crown XLS1000 rack mount power amp. I found I needed more stage volume in different situations.
          Played a fair pavillion this summer, crazy loud crowd, and I could barely hear myself over the din of ~3000 people.... Anyway, also have the problem in a lot of outside gigs, where your sound just evaporates. For one gig, I took my backup Crate PB150 and ran my practice speaker -- identical to my gigging speaker. Both are Eminence Tonker 12" in old floor monitors rated 150 Watts each. With the 2 amps & speakers running, I had good levels. I did not run twice as loud, but was no longer "topping out" the single 150 Watt amp -- you can hear some bad clipping when you do that....
          I run the XLR of my POD-HD500 to the soundman's FOH system. It got me thinking about the rackmount power amp concept. The Crown XLS1000 runs 215 Watts per channel into 8 Ohms, 350 W into 4 Ohms, and 550 W into 2 Ohms. If I run my single speaker (8 Ohm) on 1 channel, I have 215 Watts, compared to my PB150's 150 Watts.The speaker can take it. When I get into the festival/outside setting, I'll also take my practice speaker and run either Y mode (same mono signal to both sides) or go stereo from the HD500.
          The rack-mounted amps can take a lot of different speaker configurations. Running stereo or Y-mono, I'd have ~430 Watts available,but would turn it down and get a lot of headroom -- running nowhere near that actual wattage. I put the XLS1000 in a softside RoadRunner 2 space rack case. The XLS1000 is only 8.9 lbs, and in the softside rack, about the weight of a briefcase. I still take my Crate as a backup for contingencies... Just like having a 2nd guitar sitting on the rack..
          The Crown is lightweight, and not hugely expensive, around $300, but I got it on sale at Guitar Center this Labor Day for $250. It is a Class D digital amp, and is very transparent, and clean. No digital artifacts, or fizziness. It likes line level, so I run it on the unbalanced 1/4" outputs of the HD500 at Line level. The XLR balanced outs don't give you enough gain to begin with, so you'd need to run it into a little mixer to boost the signal level. The 1/4" in's of the XLS are balanced TRS (Tip/Ring/Sleeve), but work fine with unbalanced TS coming from the HD500.
          Anyway, that's my take on the Crown XLS1000 -- very workable for a guitar rig.
          Dave
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Aug 27, 2012 1:58 AM (in response to orangekrushmn)
    The other alternative is to skip the rack completely and go down the powered speaker route.  This can work very well for some people depending on tastes and application.  There are good FRFR speakers out there that will not colour your sound and have plenty of poke for use either as backline or monitoring ... or both.
    QSC  and Mackie make some nice gear (amongst others) and it is also worth looking at the new Line 6 offerings (Stagesource L3) which integrate well with the HD series and have a building reputation here for live use with a POD (the L3T).
  • jcosta_sr Just Startin' 120 posts since
    Jun 11, 2007
    Aug 28, 2012 12:43 PM (in response to orangekrushmn)
    I have an Atomic 112-50 cab.  I am interested in this:
    Reactor 50/50 Rackmount Stereo Power Amp: http://www.atomicamps.com/products.htm
    • scottyo78 Just Startin' 114 posts since
      May 29, 2006
      Sep 14, 2012 4:29 PM (in response to jcosta_sr)
      Not sure if it's (objectively) true or not but I've heard that FETs (Field Effect Transistors) are the best for producing the even harmonics which real tubes are known for. Cheap transitor amps (think Big music store house brands) produce 'odd' harmonics which sound hideous.
      I use either an older MosValve or a Crate PowerBlock (both FET amps) to drive either a single Fender and/or a 4-12" Peavey cab loaded with Celestions... both sound lovely to me.
  • cgtrox Expert Line 6 User 1,638 posts since
    Jan 25, 2007
    Sep 14, 2012 6:09 PM (in response to orangekrushmn)
    Just got mine last week and had the Crown XLS1000 waiting for it. I used to use my PODxt with a Crate Powerblock and that little thing rocks! Great for lite/mini-gigs. This Crown is actually like the Crate, a "Class D" poweramp, which means it is light as a feather and never gets that hot! I think this poweramp is a good match for the HD Pro. I run it in stereo to two seperate 8ohm loads and it gives me 215W per side. I've got 2 spaces left on top for a sliding shelf which I will be mounting my M9 and my M5. I will be setting the M5 as a full time compressor thru the loop and have a MIDI connection to the M9 which will be following the HD Pro...
    cgtrox
    • RipperShred Just Startin' 82 posts since
      Jul 26, 2009
      Sep 17, 2012 12:55 AM (in response to cgtrox)
      I take it that the xls is a very transparent amp, and sounds nothing like a tube amp? Are you using the full amp models with the poweramp modeling into real guitar cabs, or into full range with pod speaker modeling as well?
      • spikey Just Startin' 378 posts since
        Feb 1, 2007
        Sep 17, 2012 2:07 PM (in response to RipperShred)
        Im just using an ART SLA2 Power amp to the full range Peavey SP5G's and it sounds great....
        Jan 25, 2007
        Dec 23, 2012 8:22 PM (in response to RipperShred)
        I am only using the "PRE" models with a 2x12 sealed cab loaded with 8ohm V30's and it sounds really, really good once you get it setup correctly! I am running it in "STACK FRONT" mode with the bass FLAT, the treble at -40 and the focus on 150. I get some really awesome djent sounds, all of the heavy metal amp sounds are great. I am running version 2.02 and I am having problems trying to find a really nice "clean" amp that has volume when using only the PRE's. It seems like some of the PRE's are awesome just on their own, then there are a few that need a boost, then there's a few that just don't have any power on their own. I like to build from the ground up to see how the amp sounds "naked" first then start adding stuff here and there. Here she is...
        cgtrox
        • theuntolddeath Just Startin' 1 posts since
          Jan 10, 2011
          Dec 18, 2012 5:12 PM (in response to cgtrox)
          I have this exact setup.Just got the pwoer amp today.Im Just not sure on how to hook up to my 4x12 280watt Mesa cab?
            Jan 25, 2007
            Dec 23, 2012 8:21 PM (in response to theuntolddeath)
            More than likely your cab has an 8ohm MONO and 4ohm STEREO option, correct? Use the unbalanced outs from the HD Pro, split the poweramp to run both channels at 4ohms which gives you around 350W per side, then go out to the STEREO jacks on the cab....
            cgtrox
            • thomasmorgan0205 Just Startin' 2 posts since
              Jan 3, 2013
              Feb 9, 2013 8:41 PM (in response to cgtrox)
              Hey what's up brother! I was wondering if you could help me out. I am using the Pod HD Pro, Crown XLS1500, and a 400w Orange PPC 4x12 and I was wondering how to get it all to work together. I get the idea of using the XLR to 1/4 to connect the HD Pro to the power amp (I wish I could just use 1/4 to 1/4, but we all can't have what we want), but I was curious how to connext the Crown XLS to to my Orange cabinet from there? What kind of cable do you use to run to your cabinet? Thank you very much man.
        • thomas12452 Just Startin' 20 posts since
          Sep 19, 2009
          Jan 19, 2013 7:38 PM (in response to cgtrox)
          Hey I have the exact same setup but I'm using the balanced outputs into a stereo orange cab. I have the xlr's running between the hd pro and the crown on the balanced input. Then I use two speak on to 1/4 cables between the crown and my 4x12 orange. For some reason its not sending sound to my orange cab. The sounds is definitely being picked up from the line 6 to the crown though. Am I doing something wrong lol. I'm so frustrated I just wanna play this thing already.
  • lukegeis Just Startin' 45 posts since
    Apr 2, 2012
    Dec 19, 2012 2:48 PM (in response to orangekrushmn)
    I'm rocking the Rocktron Velocity 100. It is a nice amp and can get plenty loud. I run it into an old H&K oversized 2x12 ported cab ( awsome cab that sounds as big as a 4x12, but is 3/4 the size ) and it rawks. The amp can be found used for around 100 bucks.
    Sep 19, 2009
    Jan 18, 2013 10:00 AM (in response to orangekrushmn)
    Hey I just bought a Line 6 hd pro and a Crown XLS1000 myself today actually. I was wondering how you run the HD Pro into the XLS1000? I want to run it into a 4x12 orange if this is possible.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
