Aug 27, 2012 2:42 AM
Pod xt live noise when connected through USB
Like (0)
I have a POD XT Live. It generates a loud buzz when i connect it to my mac through USB.
I have an iMac 21 inch i5. I'm running OSX Lion and have all drivers, device firmware and applications up to date on line6 monkey.
Connection:
Guitar--> Podxtlive
Podxtlive--> Mac via USB
The pod and my mac are plugged into the same power source. I also tried using a different PSU for the pod.
When the usb cable is disconnected there is absolutely no noise from the pod.
How are you monitoring the PODxt?
What other PSU did you use?
same issue here. Variax 500 and pod XTL are clean when the USB is not plugged in. tried different USB cables as well. I monitor the "mix" through headphone jack on XTL
OSX 10.4.11
I've upgraded everything as much as I can with my current setup. I like to play with usb to play along with backing tracks and tweak sounds as needed.
