Aug 30, 2012 6:18 AM
POD X3 Live ( Use only for Effectes or True By Pass)
Like (0)
I have a POD X3 Live. Ive recently bought a BOSS BD 2, Boss RC 30 and a EWS Little Brute Driver. I normally connect my Boss BD to the EWS Little Brute Drive (Which happens to a True By Pass) then to the X3 Live , then to the Looped and finnally the PA. Im just wondering if the conversion of analogue to digital to analouge will create a loss of sound quality. Is there a way that I could by pass the POD X3 live and have only the EWS or BD2 played when required.
Also Is it possible to pnly have my POD to be used for effects like delay, modulation etc and have everything else True By passed?
Thank You
there is no true bypass possible on the x3
Cool.. COuld you help me with the other question if possible
not familiar with all your other gear... but every stomp and every patch cable could affect your tone... sure you can use it for just effects...
you might even look up the 4CM (4 cable method) so that you can do both... you really just have to try to find out what would suit you.
