839 Views 9 Replies Latest reply: Mar 15, 2013 11:44 AM by mishulix RSS
rucademoura Just Startin' 30 posts since
Apr 12, 2012
Aug 30, 2012 1:30 PM
USB WI-FI STAGESCAPE
http://line6.com/support/docs/DOC-2734
Anyone tried any sucessfull usb adapter wi-fi not included on the 3 ones mentioned by line 6 support?
  • Clay101 Just Startin' 1 posts since
    Oct 19, 2012
    Oct 22, 2012 12:31 PM (in response to rucademoura)
    Re: USB WI-FI STAGESCAPE
    is there a technical spec on the usb connection to check for compatibility? The engenius and samsung arent available in australia except via import and I would rather find something with local support. Also Apple iPads were released here with 4G that didnt function on our bandwidth in australia and they didnt acknowledge until it hit the press. now they only confirm 3G. this makes it a scary environment to try and confirm compatibility.
    can this be done on Android?
  • nploojsiabhurt Just Startin' 1 posts since
    Oct 30, 2012
    Nov 24, 2012 11:56 AM (in response to rucademoura)
    I'm having problem finding these USB WiFi adaptor that support this M20D (EnGenius EUB9801, LinkSys AE1000 and Samsung WIS10ABGN.) Why put a limitation road block for a nice system?  I've just bought this system for over $5,000.00 so that I don't have to sit in the control room.  I've tried at least 3 famous electronics shop (Microcenter, Best Buy, ....) in my city and none of them carry the above USB WiFi model. They said that the AE1000 is replace by the AE1200 and this model didn't  even recognize by the M20D.  What to do next?  Return the product is my solution.  Or why don't you just through a $20.00 product that will work with the system to save your customer time and trouble.  Is not that we don't want to buy but because it is not available out there!!!
    Thanks,
  • RaLi1806 Just Startin' 2 posts since
    Mar 2, 2013
    Mar 6, 2013 11:39 AM (in response to rucademoura)
    SAMSUNG WIS12ABVNX works fine as well!
    Not EnGenius EUB600 though.
  • hamkom Just Startin' 3 posts since
    Mar 14, 2013
    Mar 14, 2013 12:07 AM (in response to rucademoura)
    Just orderd a m20d with 2 l3t and waiting !!!
    My question: Can i use every wifi-stick with the Ralink RT 3572 chipset? There are a lot more than the ones in the official Line6-list. Especially there are some that i can purchase in germany!
    • mishulix Just Startin' 16 posts since
      Feb 9, 2013
      Mar 15, 2013 11:44 AM (in response to hamkom)
      I am using a Apple USB to ethernet adapter and then linked with a ethernet cable to a TP-Link TL-WR841ND wireless router. It's a cheap router but has 2x5dB gain antennas, so it works at greater distances than a USB stick or Airport Express. Works flawless, i have no problems so far, but just used them first time today.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
