499 Views 6 Replies Latest reply: Sep 18, 2012 7:55 PM by Apologist RSS
gus_cradd Just Startin' 5 posts since
Sep 28, 2011
Sep 18, 2012 3:00 AM
POD HD Pro and FBV Shortboard MKii
Hi guys
I have recently purchased both a POD HD Pro and FBV Shortboard MKii and they're both great!!!!
I can use the shortboard to change banks, patches, and to control what FX are in the chains on said patches.
Only thing I'm having problem with is calibrating the expression pedal on the FBV to control the volume/wah on the HD Pro.
Can anyone help please as I need it urgently for a gig soon!!!
Cheers
Angus
  • Apologist Iknowathingortwo 638 posts since
    Jan 24, 2007
    Sep 18, 2012 4:05 AM (in response to gus_cradd)
    Re: POD HD Pro and FBV Shortboard MKii
    Calibration Procedures
    Note: FBV Mk II controllers will need to have firware 1.10.0 or later installed for the calibration procedure, using Line 6 Monkey 1.31 or later.
    (Note: Before performing the calibration routine, please disconnect any expansion expression pedals IE: EX-1)
    1) Hold the D button while connecting the CAT-5 cable on the FBV. The display will read “CALIBRATE PEDAL” until the D button is released, at which point it will read “1 PEDAL TOE”.
    2) Press and hold the internal pedal toe-switch until the LCD changes to “2 PEDAL MIN”.  This should occur instantly.
    3) Set the heel to (minimum) position, press the D button.  The LCD will change to “3 LCD MAX”.
    4) Set the toe position (maximum) and press the D button.  The LCD will change to “CHECK VALUE 127”.
    5) Move the pedal and verify that the value reaches 0 in the minimum position and 127 in the maximum position.
    6) Press D to exit
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
