Sep 24, 2012 10:51 AM
POD HD Pro and reamping
Like (0)
Hi !
I'm sorry this question has been already discussed but that's not clear to me...
How do I have to plug the HD Pro ? (I actually own a HD 500 I'm gonna sell for a Pro because of the reamping option)
I guess it works as the HD 500 : Guitar > POD SPDIF Out > RME Fireface SPDIF In (I made a lot of test, SPDIF seems to be the best sounding output)
But what next ?
Thanks ![]()
Ps : I wonder why Line 6 doesn't make a damn plugin version... It would be SO MUCH easier to use !!!!
SPDIF (or one of the other non-USB digital outputs) is definitely the best way to get audio from the Pod to your DAW - no additional D/A - A/D conversions.
as far as re-amping... the pod pro does not have that built in. it has a "dry out" connection, but that's just a tap off the guitar input, similar to a passive DI box. To reamp, you would need to send a 1/4" output from your audio interface to the Pod's Guitar In.
and FYI, the Pod HD 500 is capable of sending the dry guitar signal to an audio interface via SPDIF. there's an option in the system menu to have SPDIF send the final output or the dry guitar signal.
So, the only advantage the Pro has over the HD500 here is that it has the dry out analog connection. But if you can monitor your processed signal without using SPDIF, you could record the dry signal using SPDIF, then re-amp identically to how you would on the Pro.
