1392 Views 18 Replies Latest reply: Mar 8, 2013 3:29 AM by Tetsujin RSS
struttler Just Startin' 4 posts since
Feb 16, 2012
Sep 29, 2012 12:58 AM
Ux2 crackling artefacts with mountain lion
I have mountain lion 10.8 and the very latest driver for my ux2 which I waited for over a month to resolve the crackling problem , I downloaded the update for my ux2 yesterday and the crackling and popping artefacts are still there. I use Logic Pro 9 on a mac.Is anyone else STILL experiencing these issues ?i have left 3 support tickets with line 6 and I have still no reply.....terrible customer service !
  • heartcall Just Startin' 5 posts since
    Jul 6, 2009
    Sep 29, 2012 7:12 AM (in response to struttler)
    Re: Ux2 crackling artefacts with mountain lion
    I am having to exact same issue... anyone have any thoughts, or solutions?
  • rjpalombo Just Startin' 10 posts since
    Feb 18, 2011
    Sep 30, 2012 8:47 AM (in response to struttler)
    The new update is said to fix this. So I installed the new Update yesterday. Guess what? Now the driver crashes and UX2 doesn't respond at all... Not even to System Sounds. The moment you click to test a sound or adjust your volume the driver crashes and reverts back to the system driver.
    I've completed uninstalled everything and removed all the Line 6 folders across the system, restart and reeinstalled everything and this same result.
    I'm real close to giving up on Line 6. This problem has existed for months and now its getting worse.
    • Sgsummers Just Startin' 4 posts since
      Oct 13, 2012
      Oct 14, 2012 1:03 PM (in response to rjpalombo)
      Hello i just bought the UX2 and I dont hear crackleing while playing but my sound definitley drops out while playing. Im using pod farm and then recording in garage band. Once I record I hear the crackles played back to me in the recording. Also the recorded quality seems less when played back. Seems like this issues has gone on far too long and I dont see line 6 aknowleging the issue for quite a while. I might return the UX2 unless I get some feedback on whether or not they are working on it.
      My equipment:
      Mac osx mountain lion 10.8.2
      Processor  2.26 GHz Intel Core 2 Duo
      mid 2009
      8 gigs of 1333 MHz DDR3 ram
      Schecter hellraiser C-1 with emg 81/85's
      pretty new cable
  • thimo Just Startin' 5 posts since
    Mar 22, 2009
    Oct 30, 2012 8:57 AM (in response to struttler)
    My working solution ...until now...
    - install the latest driver (7.1.9) problem is still present after that on 10.8.2 but in my case it's coming an going in period (maybe a minute...)
    - go to system preferences -> Line 6 Audio Midi-Devices then try to INCREASE THE BUFFER SIZE
    ...after that I played on instrument input about 10 minutes without any crackling/ artefacts... Good Luck! Please let me and people know If it works!!!
    ...Never touch a running System... it's hard to learn that... I just upgraded from OSX 10.6.8 to 10.8.2 yesterday... I thought after that long time since the release of 10.8 all heavy problems should be solved... Now I am thinking about going back to my Time Capsule Backup of the latest Snow Leopard state... Since Mountain Lion there are many performance lags... slow Logic Pro 9 GUI and now this UX2 crackling Problem... I hope it's gone now...
    Short Info about my System:
    Macbook Pro 13" (early 2011) • OSX 10.8.2 (Mountain Lion) • Logic Pro 9 (9.1.8 1700.67 32-Bit Mode) • Line 6 UX2 (Driver 7.1.9) • second Full-HD Monitor via DP/HDMI • also using Apple TV...
  • macdeveloper Just Startin' 6 posts since
    Oct 27, 2012
    Nov 1, 2012 6:44 AM (in response to struttler)
    i thin kat the problem is due to line6 usb driver for osx, beacuse i have another audio interface(an old ua-5) and it work very well with the 10.7 driver....
  • willguitar97 Just Startin' 2 posts since
    Jan 31, 2010
    Nov 20, 2012 1:47 PM (in response to struttler)
    Hi there, I am having this problem to but It only occurs around 50% of the time. When I boot up Garageband I then plug my UX2 in and it seems to work, however whenever I try to use another application, like playing a youtube video it crashes. Thinking of getting a presonus next time as I don't really use Pod Farm. Hope they fix it while I save though!
  • wigginsn Just Startin' 9 posts since
    Sep 23, 2008
    Dec 4, 2012 3:42 PM (in response to struttler)
    I had the same issues and couldn't sit around waiting for Line 6 to help so tried a few things and I have some solutions
    SOLUTION 1: Apogee One purchased and installed - works fine!
    SOLUTION 2: I used time machine and rolled back to Snow Leopard.  UX2 now working as normal.  Not ideal though because data added to apps such as Aperture during the Mountain Lion period was not accessible, so.....
    SOLUTION 3: Created a 60Gb partition on my Macintosh HD. Made a clean install of Mountain Lion on the partition.  Downloaded most recent drivers (Sept 2012) and the UX2 is now working as normal for the last week and no signs of distortion. No other 3rd party apps such as Spotify, Skype, Flip4Mac, RealPlayer, LogMeIn were installed in the partition - just ML and Line6. The bare minimum for making music. Likelihood is that the problems are caused by either upgrading from previous OS to ML, upgrading from previous Line 6 drivers, conflicts with other apps.
    I hope this helps some of you
    Nigel
    iMac
    10.6.8 (Snow Leopard) & 10.8.2 (Mountain Lion)
    3.06 Ghz
    4GB
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Jan 17, 2013 9:25 AM (in response to struttler)
    Hello,
    We have just released our latest Mac driver v7.2.1 for Mac OS X to fix the problem where USB Devices become unresponsive after using POD Farm, recording/playback in a DAW, or using other audio programs.
    This driver also includes changes which may improve the noise or distortion issues some OS X 10.8 customers have experienced.
    Please use Line 6 Monkeyn to update or download the driver directly from our website:
    http://line6.com/software/index.html
    If you continue to have problems with audio using our latest 7.2.1 driver for Mac OS X, please submit a support ticket:
    http://line6.com/support/tickets/add.html
    Regards,
    Line6Hugo
  • Eureka1 Just Startin' 1 posts since
    Mar 5, 2013
    Mar 5, 2013 2:49 AM (in response to struttler)
    Hey everyone. I think I might have an answer. First of all I must state, I do not use any Line6 software nor am I in the music game. I fool around from time to time but that's about it. I'm a professional cisual artist first and foremost. Like I said, I might have something for yall to all try. Let me explain my audio issues. For the longest time I stayed on Snow Leopard 10.6.8. Probably the best OS know to man, haha. Anyway, I "upgraded" to Lion 10.7.2 and had TONS of audio issues, I reverted back to SL. Aside from my professional gig I play MMO video games quie regularly and one of the games I play is no longer going to be supporting anything below 10.7 Lion. So I upgraded to Mountain Lion... and guess what? Audio issues EVERYWHERE. I was fearful that the audio might become an issue with working in FCP and it certainly became an issue when doing any kind of recording. The most noticeable was in Garageband, crakling and popping was everywhere whenever I used 3rd party VST or other plugins. I searched and dug on the interwebs and only found other people with the same issue. I put 10.6.8 on a partition and just switch OSs if I needed to do something with audio. That's when it hit me. I remember reading somewhere that some people supposed the issue was related to USB 3.0 support on older machines without USB 3.0 ports. Something to do with the core audio component. I made a copy of the core audio component on the Mountain Lion partition then took the Snow Leopard core audio component and overwrote it. So far everything is working wonderfully now.
    TL;DR version
    1. Make a copy of the core audio component in Mountain Lion (keep it somewhere safe)
    2. Overwrite the Mountain Lion core audio component with the one from Snow Leopard 10.6.8
    3. Hope it works!
    (the core audio component is in /system/library/components/CoreAudio.component)
    GOOD LUCK!
    • Tetsujin Just Startin' 5 posts since
      Jan 30, 2007
      Mar 8, 2013 3:29 AM (in response to Eureka1)
      Tried the Snow CoreAudio - killed my internal speaker ouput for some reason - no beeps & squeaks, which I guess I could live without anyway.
      But it didn't fix the issue I'm having with the recent drivers on 10.8.2.
      For me, 7.1.9 is fine - the occasional crackle I can live with, flipping to the Finder & back fixes that, as I'm using Cubase ASIO with 'release ASIO driver in background' enabled, so this toggles the audio off/on.
      With any driver from 7.2.1 to 7.2.4 I just get total dropouts in the UX output. Nothing reads on the meters, total silence. Can take anything from 5 minutes to an hour - but when it happens, only a reboot fixes it.
      I'm going back to 7.1.9 (yet) again... & ML CoreAudio.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
