209 Views 6 Replies Latest reply: Oct 10, 2012 2:44 PM by RonMarton RSS
BUROB Just Startin' 3 posts since
Apr 3, 2007
Sep 29, 2012 6:14 AM
Headset compatible for xd-v75tr
I have ordered the new v75tr system to replace an aging and muffled sounding Sennheiser we-100, I tried the v30hs but the head mic has probably the worst handling noise I have encountered, if touched anywhere it sounds like a bomb going off so a def. no-no, also the v70 mic is Omni- which are worse than useless for live work as they picks up everything and feed back. I own 2 Shure Beta 54 headsets and have been trying to get answers as to will they work on
this system, handbook says they need +5v supply, yet all modern belt packs are 2x1.5v powered. I am loath to fork out for yet another new headset as they
were expensive to buy. I did see a thread extolling the Crown head-mic but these are now obsolete, The countryman Isomax looks a good bet but are hard to find in uk. Why L6 do you not have a quality hyper-cardioid headset in the range?
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Sep 29, 2012 10:12 PM (in response to BUROB)
    Re: Headset compatible for xd-v75tr
    The Line 6 beltpacks all supply 5vdc bias voltage.  If your Shure mics are wired for Shure beltpacks they should just plug in and go.
      Oct 13, 2008
      Sep 30, 2012 9:25 AM (in response to BUROB)
      As a general rule cardioids will have a much higher handling noise than omnis.
        • RonMarton Iknowathingortwo 357 posts since
          Jan 12, 2012
          Oct 10, 2012 2:03 PM (in response to BUROB)
          G'day from a fellow line array enthusiast ! (HK Audio's "Elements", in my case.)
          As you've
          1. Been happy with the sound of the Shure WBH54,
          2. Have already rewired TA4 plugs and
          3. Stand to lose very little should my suggestion not work out
          ...I'd suggest trying a few cents worth of "gain-making" resistor inside the TA4F connector of your existing headset/s before you spend hundreds of bucks on something like Countryman Isomaxes.
          Go for the physically smallest (lowest wattage) you can find in the 5-10k ohm range, soldered in series with the pin 2 "bias" connection and have a listen.
          If it passes the listening test, I'd also suggest that the "final roadworthy version" should have its resistor and connections protected from bump-induced fracturing and short-circuits by dint of filling the inside of the TA4F connector with silicone sealant "goo".
          Jan 12, 2012
          Oct 10, 2012 2:44 PM (in response to BUROB)
          Just as a matter of interest, here are two alternatives from Beyer that should just "plug and play", but I've not heard of anyone who's actually tried them with Line 6's TA4-equipped beltpacks.
          http://www.soundsliveshop.com/p/Beyerdynamic_TG_H54c/BYR-TGH54C-TAN
          http://www.soundsliveshop.com/p/Beyerdynamic_TG_H74c/BYR-TGH74C-TAN
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
