1018 Views 12 Replies Latest reply: Feb 5, 2013 3:37 PM by armandobravo4L RSS
niall182 Just Startin' 10 posts since
Apr 19, 2008
Oct 6, 2012 3:58 PM
Pod HD Pro best i/o set up options into power amp & into 4x12??
Hi all,
Just got my Pod HD Pro rack unit...been playing with it for a day or so...cant quite figure out what the best i/o options are???...I'm running the HD into a Rocktron Velocity 300 power amp and into a 4x12 cab....should be fairly straigt forward I thought to hook up...flick the switch on the back next to the outputs to 'amp' go into the menu and choose either 'stacked power amp' or 'power amp' and go from there...to be honest it doesnt sound very good!!...in fact it sounds much better if I flick the switch to 'direct' and select 'studio/desk' out as an option and go to my power amp and 4x12, though that sounds a bit muddy...my question is: what would be the best i/o option for my set up...am I doing anything I shouldn't??...I'm running the latest firmware.
Why do line 6 make this stuff so difficult and why dont they just do a simple bank of patches for 'live' use ie: gig volume...that volume being slightly over and above a real drummer with a real kit!!!...that aside I can tell that there are some really good sounds hiding inside and yes part of the fun is to dig them out....but the i/o hassle I'm suffering with at the moment is a bit frustrating so any tips from someone who uses these live through a 2x12 or 4x12 cab would be much appreciated.
Cheers for now
Niall
  • cgtrox Expert Line 6 User 1,638 posts since
    Jan 25, 2007
    Welcome aboard man! I just got mine a few weeks ago as well. It really depends on what you have as there are so many options to choose from. You said you have a poweramp and a 4x12, you're right where I am except I have a 2x12. I am using a Crown poweramp and an M9 in the effects loop. I have two XLR to 1/4" cables going from the poweramp to the "unbalanced outputs" on the HD with the switch set to "line" on the back. I am only using the "pre" models for everything as I am using a real guitar cab. Also, by using the M9 in the loop and saving some DSP I can use dual amps on all of my patches! The best part about the M9 in the loop is if you hook up a MIDI cable from the HD to the M9 the M9 follows it with each patch! So, you can include it for programming each patch! You are only going to use the first four pages for I/O setup unless you have a Variax or a DT series amp.
    Page one: I left all alone except #4, turn on trails
    Page two: #3 at 50hz, #2 tap ON, #4 FBV on
    Page three: #3 AUTO, #4 Global
    Page four: #1 stack front, #2 FLAT, #3 150Hz, #4 set at -40
    The critical one is #4, just because it says poweramp and cab doesn't mean you have to use that one. I liked the stack front best and also mess with #2,#3 and #4 with the 4x12. Those are the best settings for my 2x12. Also try amps with the cabs on, maybe you will like it. I have spent all day today setting it up and testing it with the MKI shortboard to see how it works with it and I finally had time to run down to GC and get some cables. So far so good, there is only the 2.02 version right now, just waiting on the latest update!!!
    cgtrox
    • spikey Just Startin' 378 posts since
      Feb 1, 2007
      Nice stuff there cg... Nice stuff indeed...
        Jan 25, 2007
        Good deal bro! Yeah, I got the 2x12 for the same reason! The good thing about Line 6, is the options! Everybody has a different rig, guitar, cab, etc. so everybody has an option they can use. When you find the right settings for you it works great. I'm still kinda tweaking here and there, but I will post everything when I'm done. The "lift" button is for the ground, do you mean "line"? I use "line" on mine. The XLR balanced out has both mic/line and lift/grnd, the unbalanced has only line/amp. I'll be in touch...
        cgtrox
            Jan 25, 2007
            Just found more DSP space! Moved the M9 completely out of the loop and put it between the poweramp and the POD HD! The effects loop leaves a lot to be desired anyway, hope they fix it in the update! Now, everything sounds clearer. Another thing is I am using my MKI shortboard just to see how much I can get away with. The main thing that sucks is the wah/vol pedal have to have an FX block to work. Again, the update! But, I can program FS1, FS2, FS3 and FS4 to work on stomp, mod, delay and reverb. The cool thing is, once you programmed them to turn off and on you can move them anywhere in the chain and it still controls them! Still looking for more stuff...
            cgtrox
              Feb 1, 2007
              cgtrox
              You too??? I thought it was just my ears.... Interesting...
    • armandobravo4L Just Startin' 1 posts since
      Oct 2, 2012
      I see it's a Crown poweramp, but could you specify the exact model and how the inputs work from the pod to the amp?
      email me if possible; thearmandobravo@yahoo.com
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
