648 Views 17 Replies Latest reply: Oct 30, 2012 7:58 AM by snhirsch RSS
shawnmx Just Startin' 16 posts since
Jan 9, 2007
Oct 12, 2012 4:24 PM
How do you change strings on the JTV-69?
I'm the proud owner of a new Lake Placid Blue JTV-69. But I'm not a fan of 10-gauge strings and I wanted to replace the factory strings with some 09's. I removed the factory strings without too much trouble. But now I'm having all kinds of problems getting the new strings on.
First off, after removing all of the original strings, the bridge popped up like this:
I've changed strings on guitars with tremolo-style bridges before and I've never seen one pop up like this. But I figured this is probably normal, and the bridge will readjust once the new strings are in place. Beyond that, when I try adding new strings to the guitar, I can't get them to stay seated in the bridge. No matter what I do, they eventually pop out. Considering that there aren't any other forum posts covering this topic (I've searched around), I'm thinking that there's something obvious I'm overlooking here. Any advice you can provide would be appreciated.
  • XCrossroadsX2000 Just Startin' 38 posts since
    Feb 24, 2011
    Oct 13, 2012 9:57 AM (in response to shawnmx)
    Re: How do you change strings on the JTV-69?
    Congratulations on your new JTV.
    I found the easiest way to do this is to remove the A through B strings leaving the 2 E's on. I'll loosen those strings a little so I can get underneath and clean my fretboard.
    Then i replace those 4 strings and then change out the E's.
    Slide the string through the locking tuner and then position the ball of the string in the tremlo and hold it there with your right hand. Use your left hand to take up the slack and the lock the tuner.
    Keep your right hand on the tremelo until you have enough tension that it won't slip out.
  • gtrman100 Iknowathingortwo 479 posts since
    Jan 24, 2007
    Oct 13, 2012 8:39 PM (in response to shawnmx)
    Under normal conditions, it's not a good idea to remove all the strings on a guitar at once, unless you are going to be cleaning the fingerboard, adjusting the truss rod(on Fenders with the adjustment at the bottom of the neck), fret leveling, etc because it takes all the tension off the neck and could change the bow of the neck. Also,with a trem guitar, you will mess up the bridge setup, as you have found out. I usually take off the high E string, and replace it, then go onto the B string, etc.
    I would fix your situation by using XCrossroadX's solution, but put both E strings on and tighten the strings a bit until the bridge is locked in place. Then add the other strings, and tighten them little by little until the bridge is a the proper angle. then I would tune the guitar to pitch, and stretch the strings one at a time until the tuning is stable. Hope this helps.
      • davidb7170 Just Startin' 253 posts since
        May 3, 2008
        Oct 14, 2012 1:30 PM (in response to shawnmx)
        I've had a strat for years, and don't recall having any problems with this. Then I looked at your picture closer, and saw that there are 2 pivot posts.... My strat is the old school type with 6 screws holding the front of the trem bridge down... I have a JTV-59 (LP style -- no trem) and have always taken all strings off at once when I change 'em. I just ordered one of the new JTV-69S in shoreline gold, so will need to keep this in mind. Thanks for the heads up. Don't really recall that much turning up on the forum about this issue. Will probably need to change my ways in string changeout. I do usually oil my rosewood fingerboards when I do a change and have everything off. One other thought might be to loosen or disconnect your trem springs, as it looks as though the tension of the springs is what pulled your trem block forward and the top part went backwards enough to disengage from the pivot studs. It seems the newer strats have moved to the 2 pivot posts as well -- wonder how they make out with this?
        Side note -- the method of never taking off all strings is how you'd normally restring a guitar with a trapeze tail piece and floating bridge, like on an archtop. I used to have a Gretsch Country Gentleman that had a Bigsby trem and a floating bridge (just sat on the top -- no posts, etc. to keep it in place). It was a beautiful guitar, but a pain to change strings on. If you moved the bridge in the process, it would screw up your intonation big time.
        Again, thanks for the heads up. I'm supposed to get my 69 Tuesday, so will see what I will need to deal with.
        Dave
  • markcockerill Just Startin' 246 posts since
    Dec 7, 2007
    Oct 14, 2012 6:32 PM (in response to shawnmx)
    I tie a shoe lace round the body and over the trem arm which holds the bridge in place then snip all the strings with wire cutters. Bridge stays put every time. I always clean the neck and frets every string change.  I soon as I have all the new strings in place and locked the tuners I remove the lace before bringing back up to pitch. I'm sure you will find what works for you.
    • capetown Just Startin' 1 posts since
      May 15, 2007
      Oct 17, 2012 1:49 AM (in response to markcockerill)
      I have a JTV 69 with the first generation tremolo. I also change the strings all at once. I have used the same trick to fix the bridge. That works fine.
      However, I would like to recall another of the original problems of shawnmx. Changing my strings for the first time also raised the question what the
      correct final position of the string ball is. I actually experienced  that there may be two final positions of the string ball, one where you can see him
      from a top view on the guitar, another one where its fixed more lower in the bridge (you can check it by looking at the balls from the tremolo rear view).
      What is your experience with that?
  • bigglesdog Just Startin' 15 posts since
    Oct 8, 2012
    Oct 17, 2012 9:42 AM (in response to shawnmx)
    Interesting. I changed the strings on an eBay '69 that just arrived and removed all the old strings at once to give it a clean and the tremelo did not pop up like that, in fact the whole process was easy. Is this a redesigned bridge or does the fact that I had the tremelo bar removed lock the bridge in some way?
      Dec 7, 2007
      Oct 17, 2012 10:35 AM (in response to bigglesdog)
      I will add that I didn't have any problem until I added an extra spring.
      • snhirsch Just Startin' 67 posts since
        Oct 17, 2012
        Oct 30, 2012 5:31 AM (in response to shawnmx)
        The next time Line 6 does a manual revision, it would be helpful to add a couple of pages on basics such as string replacement.  Some of us have better intuition than others regarding mechanical issues.  Although I like to count myself in the first category, it was still a bit unclear how to fasten / wind the strings around the tuning pegs in a manner that best avoids slippage.  There should also be some verbiage (and pictures!) covering bridge and tremolo adjustment.
        Otherwise, I'm reasonably happy with my new JTV-69.
        • phil_m Expert Line 6 User 4,243 posts since
          Jan 25, 2007
          Oct 30, 2012 7:48 AM (in response to snhirsch)
          With locking tuners, you don't really need to wind the strings around the tuning pegs at all. Actually it's probably better if you don't. Just turn the tuning pegs so that the hole running through shaft is roughly parallel with the nut, pull the string through until its taut, lock it in, and you're good to go. Once you've got them all replaced, you're good to go.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
