361 Views 9 Replies Latest reply: Oct 20, 2012 2:43 AM by CaptainU RSS
CaptainU Just Startin' 9 posts since
Aug 22, 2012
Oct 19, 2012 7:42 AM
POD HD500 Looper accidentally engage - Solution
I've posted this from an earlier post as a separate discussion as it should make it easier to find for anyone searching for this specific problem...
If, like me, you've read all the discussion/advice on the problems of accidentally engaging the HD500 looper in live situations (which, unbelievably, I did three times in my first gig with this unit) but can't find a solution then I hope this helps.
Unfortunately, for some reason, the 'hold4looper' function is definitely NOT part of the HD500 (unlike the 400) although I've suggested it in an update (don't hold your breath). And official Line6 support couldn't help.
So the challenge was how to prevent my clumsy size 9' boots catching the looper button on a dark stage whilst going for FS4 or the Expression Pedal mid-riff!
Rather than disabling it or rendering it unusable I still wanted to be able to have it as a feature. I've got what seems to be a very workable solution so far. A fairly wide elastic band looped around a few times so it's tight around the stem between the footswitch cap and switch body (see picture). This gives enough resistance so the switch doesn't get depressed accidentally when going for FS4 or if slipping off the expression pedal. It does, however, still allow me to use the looper switch at any time by giving it a definite firm push down with the foot (pretty much like the Exp Toe Switch pressure).
Anyone doing the same will maybe need to experiment with elastic bands and/or number of loops to get the required effect.
I think I'll get / make a small flexible rubber collar which would fit snugly as a more permanent fix (but TBH now it's sorted I'll probably just end up leaving it!).
Anyone with a more elegant but equally usable solution please chip in!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
