112 Views 1 Reply Latest reply: Oct 26, 2012 6:33 AM by phil_m RSS
rockum Just Startin' 3 posts since
Oct 18, 2008
Oct 26, 2012 6:22 AM
Which Amp Model for Pedal Steel
Any suggestions which amp model I should use for Pedal Steel?  None of the standard amps used for pedal steel, like the Peavy Session 400, are currently emulated, and I don't know enough about the ones that are to know where to start.
Thanks
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Oct 26, 2012 6:33 AM (in response to rockum)
    Re: Which Amp Model for Pedal Steel
    The Session 400 is a 200W solid state amp (where the 400 in the name comes from, I'm not sure), and its biggest selling point for pedal steel seems to be loads of clean headroom. In the HD500, I think the amp model with the most clean headroom is probably the Twin, but you probably need to get into the DEPs to maximize that. That would be where I'd start, anyway. Are you looking for something that's super clean? You might actually be able to get away with not using any amp model. Or you could put a dry path in parallel with the amp model. It really depends on the type of amp tone you're after.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
