658 Views 12 Replies Latest reply: Dec 7, 2012 9:39 PM by GugaWedge RSS
GugaWedge Just Startin' 11 posts since
Jul 29, 2012
Nov 14, 2012 2:22 PM
DT50 high noise floor (hiss) solutions
Hi guys,
There are a bunch of threads that mention issues related to this one, so I was thinking if we can try to make one that can provide ideas on how to fix/workaround the issue.
I have an open support ticket with Line6 at the moment regarding this issue and will keep you updated on any solutions that might be coming from them.
Here is the transcript of the ticket so far: (This also details the issue that me and a lot of others are complaining about...)
Hi guys, Just bought a DT50 (to add to my collection of POD plus variax) and unfortunately is suffers from excessive "crackling" noise (sometimes refered as white noise, or waterfall sound). This is not my first tube amp, so I am guessing from experience that this is probably an issue with one of the tubes. I know I could get a ticket and get in touch with the nearest support center, but unfortunately the closest one is +1500kms away from where I live. (Welcome to Australia). So as you can imagine I really don't want to ship the amp there just to replace the valves. So if you guys can help me to narrow down the problem to a valve issue, I would be more than happy to replace them. I will try to give you as much info as possible on the issue: Amp is working fine (except for the noise...) in both channels, all the modes/voicings, both in low and normal power modes. With the power on and in standby mode there is no noise whatsoever. Turning the standby mode on, voicing 1, pentode, class A/B, there is no hum (just the normal from a tube amp) and a low crackling noise (sounds almost like static from an old radio). Changing to voicing II, the noise increases every so slightly. Voicing III is the worst one. Not acceptable. Voicing IV is on pair with Level I or II. Changing the mode from pentode to triode attenuates the noise somewhat. Changing class makes almost no difference. Changing Volume/Master level has zero impact on the noise. Running the amp with nothing plugged in, direct guitar or POD has zero impact. I have tried to remove the tubes and reinsert them (maybe they would have gotten loose during transportation...). This had a very minor impact on the noise, reducing it very slightly. Leaving the amp running for long periods also makes the noise reduce slightly but remains stable after 5 minutes or so. Ok I hope that is enough information so you guys can help me out to diagnose the source of the issue. Thanks in advance for your help. Cheers. Hugo Fonseca
After some more troubleshooting (and head scratching) here is some more info:
Removing either of the preamp tubes and turning the amp on makes the noise go away.
There is a slight difference in the noise volume between channels one and two with two being lower than one.
I have swapped the preamp tubes positions with a slight change in the volume of the noise.
I have tried electric contact cleaner with no success.
Found that moving the presence knob to a value higher than around 90% increases the noise even further. Decreasing pass that mark gets it back to the "normal" level. This variation is not linear. Constant up to ~90%, higher above it.
Please disregard the differences between channel one (A) and two (B). I forgot the fact that they save the tipology and so when I was switching between the two the tipology was changing also and that accounted for the noise volume difference.
How loud is the noise when using the amp? It is normal to hear hum/noise differences when switching topology and class on the DT Amps.
Can you hear the noise while you are playing the guitar?
The reason that you do not notice this on other tube amps is that the power class and rating is not changeable so you get used to the hiss or hum over time.
I.e. in class A on and setting III or IV you are going to hear hiss because your preamp and power tubes are juiced.
On Class AB with setting I is going to be relatively quiet.
Ultimately, there is no dead quiet tube amplifier. the DT amp just might be drawing your attention to the difference in noise floor because of the gain staging implications of changing the class and topology settings.
Can you post a sound clip of the issue?
Thanks,
David
Hi David,
As I mentioned I had several other tube amps including a twin reverb, a TSL 100 and an AC-30 (which have different levels of noise and/or hum), so I am aware of the typical noise floor on tube amps.
The hum level on my DT50 is fine and as you say changes with the different settings on the amp as expected.
What is not normal is high "waterfall style" constant sound, even with all the knobs turned to 0.
The noise is noticeable even when playing at low levels. When playing at higher levels the guitar sound drowns out the noise.
I will post a sound clip of the issue tonight so you can judge for yourself.
Cheers,
Hugo
(File is attached)
<EDITED TO ADD LINK TO FILE>
http://dl.dropbox.com/u/80096498/DT50%20noise.mp3
As requested here is an audio of it. It was recorded with my phone from about 0,5m distance.
Sorry for the late reply. I don't hear anything out of the ordinary depending on your topology and gain settings. Can you hear the noise while you are playing?
You can hear hiss even with the knobs turned to 0 with the DT. This is the noise floor of the power amp.
Do you hear any pops, clicks, monophonic feedback, doubling sounds?
Thanks,
David
Hi David,
You can definitely hear the hiss while playing at low to mid volumes. It gets drowned out while playing at gig level, but it is still unusable since even muting the strings/using a noise suppressor on the effects loop won't silence it, so if for instance there is a quiet part on a song and you are playing live with a mic'd cab it becomes impossible to stop the hiss. Plus again makes it unusable for studio recording with a mic'd cab.
I have used some very noisy amps (ac30 comes to mind) and none was anywhere close to this.
Can you give any ideas on how to reduce the noise as in replacing valves with another brand or biasing the power amp ones lower? Maybe some other minor mods/tweaks?
I honestly think that the amp sounds great and am very happy with it, but the very high noise floor makes it unusable. from reading in the support forums there seems to be a bunch of other users complaining from the same thing. Also on general amp forums, every time someone is asking for advice if they should buy it or not, there is always someone advising against it because of the noise.
This are all customers you are losing because of something you are calling a "feature".
If you can somehow find a solution to reduce the noise (again no one is expecting it to be silent. some hiss IS expected), this may all be customers you are gaining back.
I would even be ok with some noise suppressor solution post power amp, so at least the hiss wouldn't be audible when not playing...
Cheers,
Hugo
Ok,  that is all the conversation so far. When i have some time I will round up the other threads regarding the same issue and provide links for them.
I also have a set of 12AX7's (TungSol) coming and will let you know it it made any difference.
Any other ideas?
Cheers,
Hugo
    • DropTheSun Just Startin' 41 posts since
      Dec 3, 2008
      Nov 16, 2012 2:15 AM (in response to GugaWedge)
      Re: DT50 high noise floor (hiss) solutions
      My DT50 212 Combo has this "feature" aswell. Setting I and II has little "hiss", that i could say is the normal tube amp noise. But when changing to setting III, the "hiss-noise" raises so loud, that it disturbs playing in low volumes (and on gigs when the combo is mic'd). Setting IIII is almost as quiet as setting I and II.
      I'm afraid that Line 6 is going to name this noise problem as a feature. Pretty irritating feature in 1600€ combo amp, don't you think?
    Dec 3, 2008
    Nov 21, 2012 3:48 AM (in response to GugaWedge)
    I manage to decrease the hiss of Voicing III on my DT50 212 Combo. I reseted (I don't know if this is the right word for it) the DT50 and that did the trick. Voicing III is still the loudest one, but much quieter now.
    Here's what i did:
    1. Push DT50/25 voicing knob DOWN. Now, at the same time push the Pentode/Triode knob UP. Keep them pushed at these positions.
    2. Now Power up the DT50/25 and keep the knobs pushed. First all the lights on DT50/25 will be on, then some of them will go off.
    3. After view seconds Channel A, Triode, Voicing I and Class A/B lights will go on.
    4. Release the knobs. DT50/25 has been reseted to factory setup.
  • nairraf Just Startin' 6 posts since
    Nov 5, 2012
    Nov 27, 2012 7:07 AM (in response to GugaWedge)
    Just thought that I would reply with my findings:
    I have had a DT50 now for a couple of weeks, and noticed, like many of you, that the noise floor was quite high.
    Based on my readings, I replaced the 12AX7's with Mesa SP12AX7's, and while it did take some of the noise out, it was not a huge difference.
    I am going to try some JJ Gold's, and will reply back with those findings, but unfortunately, not a huge difference with the SP12AX7's .
    Like many: voicing 3 is the most noisy.
    NOTE: I have also updated to 2.0 (reflashed a couple of times just to be sure), as well as try the factory reset thing. Now, I find that it is usable, but my other tube amps are more quiet that this thing. But it really does sound great, really great in fact. Just too bad about the noise.
    • CKro Just Startin' 10 posts since
      Dec 11, 2008
      Dec 6, 2012 10:12 PM (in response to nairraf)
      I just got my DT50 212. I noticed the the noise issue. #3 is the louder. When nothing is connected to the amp the noise is higher. When the HD500 is connected the noise is reduced. I've updated the firmware and the noise was reduced a little more. it sill there but is better now (3 is still the noiser). At very low gain (practically listen the string from my electric guitar) the noise kind of bother me, but i just play at that volumne when my little one are sleeping. With a no so low volumne, the noise is ok, even for quiet riffs is ok. Using my HD500, some of the effects cut any remain noise. The only thing that having crazy is when I change a present from high to low gain in my pod it makes me jump from my stool (that happened also with my normal amps, but this is worst). Overall, I'm happy with the quality and sound and the noise doesn't bother me too much to don't recommend it (I'm not so picky)
      So summary: I think I reduced some noise with the update of the firmware and with pod in low gain effects (the high gain covers the noise, so is not a problem ).
      I'm not a tube expert, it's just my experience.
      BTW, the audio you uploaded Hugo, sounds louder than my noise in possition #3.
