111 Views 6 Replies Latest reply: Nov 20, 2012 3:36 PM by jooshy58 RSS
jooshy58 Just Startin' 14 posts since
Nov 14, 2012
Nov 19, 2012 7:34 PM
help on using pod hd as interface
ok so is there anyway to have the sound from my pod going throught the usb into my compter and have the sound come out my focusrite 2i2 interface thats connected to my moniters? i hope that makes sense if not can someone give me some info on how to my pod working as an interface i tryed it out using the unbalance 1/4 inch outputs in to my monitrors and it was noisy of course but the issue was taking the direct monitor off or what ever it is so i can just use my daw software to monitor the pod. let me know guys
  • ciadude2 Just Startin' 46 posts since
    Jan 27, 2011
    Nov 19, 2012 9:08 PM (in response to jooshy58)
    Re: help on using pod hd as interface
    I imagine that you could if you set the HD500 as your input and the Focusrite as your output. How you would do that would depend on which DAW you're running in to. Like I just use my HD500 as my interface when I'm only doing guitar stuff, and if I don't mute the playback monitoring(I forget the actual term, I hope you know what I mean) I hear the guitar played twice. It theoretically should work.
      • PremiumJones Iknowathingortwo 238 posts since
        Mar 29, 2008
        Nov 20, 2012 2:05 AM (in response to jooshy58)
        Why not just plug the POD into the focusrite via 1/4" or XLR? You'll get better latency that way, you can choose to monitor however you like, you can record and playback on the same monitors without having to change anything, etc and so on.
        The USB is there for people who dont have a decent interface already.
        You do, so use it.
            Mar 29, 2008
            Nov 20, 2012 2:18 PM (in response to jooshy58)
            hmmm, I wouldnt think that would be the case.
            If you are using it in a place with lots of interferance and cables longer than 20 feet or so, it would make a difference. In the basement/bedroom, there is little to no difference.
            I have used my 300 live into a PA with 2 50 foot 1/4" cables without any noise too, so Im gonna say that isnt the problem. Maybe the amps in the monitors? Maybe some sketchy gain staging if you are using USB, since you likely arent using the Master volume in that case... if it is set too low your S:N ratio is going to hell and you will get hiss that way...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
